Hi,
I have 1 pair of Brembo Calipers from a R33 GTR for sale
superficial marks 'damage' to paint from brake fluid spill.
otherwise perfectly fine and in working condition.
Bolts included.
Pads Included.. with maybe 40% - 50% meat left..I believe they are Endless.. Havent looked any closer at them just yet.
Will be taking more pictures shortly.
Postage Included - Asking $1400. or nearest offer.
PM or reply here. usually response within a day.
Also GTR Button Clutch - 5 puck - Made in Japan, Fresh Flywheel - Has done 1000kms. Bedded in. ready for use.
Postage Included - $520. or nearest offer considered.
Thanks Matt
https://www.sau.com.au/forums/topic/241901-bncr33-brembo-calipers-front-only/
