Item: Jim Berry Racing Clutch - Full Monty - includes flywheel
Condition: Excellent used for 3 months
Price: $800
To Fit: RB26 pull clutch
Contact: PM
Comments: Used for aproximately 3,000km. This clutch is in excellent condition and was only used while I was awaiting twin plate from Japan. Clutch plate thickness is no less than 7.85 MM. Can easily handle 400 kw @ the wheels. 5,500lbs pressure plate.
post-45675-1225103514_thumb.jpgpost-45675-1225103600_thumb.jpgpost-45675-1225103669_thumb.jpg
Item: Bosch Z32 AFM's (pair)
Price: $350 pair
To Fit: RB26
Contact: PM
Comments: Pair of Z32 AFM's in excellent working condition. Great upgrade from Standard AFM's. Does require the use of pod filters on GTR's. (I have these too.) I can also supply the plugs. see below.
post-45675-1225104044_thumb.jpgpost-45675-1225104091_thumb.jpgpost-45675-1225104134_thumb.jpg
Item: Two sets of Z32 AFM plug - one standard and one aftermarket (brand new).
Condition: standard in working order - aftermarket brand new
Price: $20 for standard, $50 for brand new
To Fit: Z32 AFM's
Contact: PM
Comments: Choice of original or aftermarket
Item: 25 row oil cooler and relocation kit for RB26
Price: $400
To Fit: GTR's
Contact: PM
Comments: This kit contains everything required for remote oil cooler and filter relocation. Includes all the braided hoses, fittings and mounting brackets. Mounting kit suits front mount for R33 GTR but i'm sure it could be modified to suit other GTR's. Oil temp never went above 90 degrees even in summer with aircon.
Item: Polished Aluminium Catch can and washer bottle
Condition: Very good condition
Price: $200
To Fit: GTR R33,R34
Contact: PM
Comments: Great catch can and washer bottle setup. Includes all the hoses and fittings. Bolts into original washer bottle bracket.
Item: Excedy twin plate clutch and lightened flywheel
Condition: suits rebuild
Price: $200
Contact: PM
Comments: I've been told these can be rebuilt from Excedy Aus for much less than the price of a new one.
Please send PM if your interested,
Warren.
https://www.sau.com.au/forums/topic/242008-fs-rb26-aftermarket-parts-and-acc/
Item: K & N Pod filters, adaptors and aluminium airbox.
Price: $150
To Fit: GTR's
Contact: PM
Comments: A complete twin pod air filter set. Includes 110MM K&N filters with pollished end caps. Aluminium airbox and surround. Pollished stainless top. Aluminium pod filter adaptors to suit standard AFM's or Z 32 AFM's.
post-45675-1226917211_thumb.jpgpost-45675-1226917307_thumb.jpgpost-16727-1124539465.jpgpost-45675-1226917494_thumb.jpg
Item: Wheel spacers 20MM front and 25MM rear
Condition: Need a dust off
Price: $50 ono
To Fit: GTR's
Contact: PM
Comments: Wheel spacers to suit gtr's or five stud nissans. Includes wheel nuts.
post-45675-1226917826_thumb.jpgpost-45675-1226917928_thumb.jpgpost-16727-1124539465.jpg
hey the stainless airbox, is it an airbox or just a partition for your pods and what model GTR this fit?
Its an aluminum partition around the pods, with a stainless steel top to seal off the engine bay air. It also has a cold air intake pipe that collects air from the front spoiler. Also cold air is drawn from the factory front guard hole. Sorry, i haven't got a photo of the cold air intake.
  • 3 weeks later...
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
