I need some speakers for the new car. R32 GTST 2 door. Has the stock ones in there atm im thinking, judging by the crap sound coming through.
Ive been given a quote by braddon car stereo to install and they want 400.00 labour not including what speakers i want. Apparently the skyline needs spacers in the front and a rear shelf made up or something.
he said the seat belt something or other goes through the speakers in the rear hence the new shelf needed.
i want 6 inch in the front and rear and nothing special.....was looking at MTX or pioneer......
anyone done it themsleves (thats what i was hoping to do) or know of a good place thats done skylines before.!!!!
cheers.....
https://www.sau.com.au/forums/topic/242092-audio/
bud,
a mate and i re-did mine about two weeks ago,
we discovered that when the speakers where only being held by one screw..
so we just got some rlly thin ply wood and using a jigsaw made our own brackets so the speakers would fit snug, and screwed in with more than one screw haha
we made a template out of cardboard and then put it against the ply wood - worked a treat
Edited by astrotristan
https://www.sau.com.au/forums/topic/242092-audio/#findComment-4222961
what model???
i would not reccommend bdl at all. my mate got some focals in his font doors. expensive speakers...and they didn't put the trim seals back on properly...both speakers had watermarks on them plus crossovers weren't good.
sure they replaced them...but it's the principle yeah?
my pick would be the place in phillip. us guys at work can get cheap systems from the kenwood rep and installed through them. all the installs ive seen come out of there have been really good and ill be going to them to see what they can do about front speakers
https://www.sau.com.au/forums/topic/242092-audio/#findComment-4223924
i like the DIY approach.
+1
Just set yourself a weekend to get stuck in to it and with a bit of common sense, the right tools and some patience its not that hard... Just time consuming.
You'll save hundreds of dollars if you DIY.
https://www.sau.com.au/forums/topic/242092-audio/#findComment-4224899
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
