Hi
I've got some leftovers for A31 cefiro for sale
Headlights - 2 pairs. Both are projector style with the black background. $220 per pair
Blinkers for front bar - Orange - 2 pairs. $120 per pair
Blinkers for guards. 2 pairs. $150 per pair
S2 taillights. Complete set. $350
S1 taillights. Complete set $150
Standard Grill $80
Standard Mirrors. In pearl white. $150 for the pair
Grey carpet. Complete. Good condition. $150
White driver guard. Straight. $170
White passenger guard. Small dent. Easy repair. $120
Grey driver guard. Straight. $170
Might have some more bit for sale if I look around.
https://www.sau.com.au/forums/topic/242119-fs-cefiro-parts/
Hi
Standard Grill $80
whats the standard grill look like? my car never came with one
https://www.sau.com.au/forums/topic/242119-fs-cefiro-parts/#findComment-4238050
Sorry about the late reply. I didn't get any email notifications to this thread so I didn't know there was replies. (Should i get notifications?)
This is what the standard grille looks like
https://www.sau.com.au/forums/topic/242119-fs-cefiro-parts/#findComment-4246129
  • 3 months later...
Some price drops
Headlights - 2 pairs. Both are projector style with the black background. $180 per pair
Blinkers for front bar - Orange - 2 pairs. $90 per pair
Blinkers for guards. 2 pairs. $100 per pair
S2 taillights. Complete set. $300
Standard Grill $60
Standard Mirrors. In pearl white. $100 for the pair
Grey carpet. Complete. Good condition. $100
White passenger guard. Small dent. Easy repair. $100
Grey passenger guard. Straight. $170
A31 radiator $100
Auto tailshaft $60
https://www.sau.com.au/forums/topic/242119-fs-cefiro-parts/#findComment-4478510
  • 2 months later...
Headlights - 1 pairs. They are projector style with the black background. $180 per pair
Blinkers for front bar - Orange - 1 pairs. $90 per pair
Blinkers for guards. 1 pairs. $100 per pair
A31 radiator $100
Auto tailshaft $60
Front and rear standard bumper bars in champagne - $120 each
Some stuff sold and some added. List updated
https://www.sau.com.au/forums/topic/242119-fs-cefiro-parts/#findComment-4606132
