  • Replies 165
will probably be able to make this event.. i may even make some cupcakes hehe
we dont bake cupcakes "in da hood " it ruins our reputation :O:D
Nah we steal them from the munno don't we????????? :):P:D
  • 3 weeks later...
Im pretty keen to show up..
Although I have met no one IRL so it might be a bit weird.
dude its guna happen... if im up there getting my cook and drink on by my self well then mayb ill leave the organising to sum1 eles but until them im gna keep pushing!
    • I might do a few more high temp bed ins as described here.  I have a nice quiet 80kph road right near me.  How To Bed-In Your EBC Brakes For Street Or Track Use - EBC Brakes https://share.google/AjnOTILXoiqQnLu8p
    • I did a few 80-0 stomps. I then just rode the brakes while I applied throttle for a while to get them nice and hot. I live on a big hill and have been down it a few times also with stomps and brake riding.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
