Gday,
Having a few dramas with the skyline atm, fixing wires and stuff but today i found an unplugged box sitting on the rear parcel shelf of the skyline.
Its a little grey box that sits on the drivers side of the parcel shelf, adjacent to the right speaker. Does anyone know what this box is for??????? should i have left it unplugged? i was thinking it might be hicas related????
paul
https://www.sau.com.au/forums/topic/24242-unplugged-box-on-parcel-shelf/
Guest RedLineGTR
Not sure...check the rear under the car where the diff is...sometimes they replace the hicas system..with a special bar..to help with stabiliy on the rear end..since hicas is no drifters friend since its sometimes hard to predict what it does sometimes. Cant really shead to much light on the topic.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
