  • Replies 54
i had a stillen one on my car, it was GREAT and made a HUGE difference to handling
the 350Z ones are NOT the same. they actually come with one from the factory and it does NOT fit our car
may I ask where you got it from? and what price. thank you~
https://www.sau.com.au/forums/topic/242485-v35-strut-bar/#findComment-4232608
Warren,
I still have your Stillen one sitting in my garage...took me close to two hours and a lot of cursing two weeks ago and stripped a nut on the strut tower (the one on the passenger side hardest to get to). Will have to find time to remove tht stripped nut to install it. :(
https://www.sau.com.au/forums/topic/242485-v35-strut-bar/#findComment-4232768
Warren,
hey mate, take some pics when u doing it, and also wondering if u installed the bar, do you need to take the engine cover off? and where did you guys get ur bars? cheers
https://www.sau.com.au/forums/topic/242485-v35-strut-bar/#findComment-4232870
Warren,
I still have your Stillen one sitting in my garage...took me close to two hours and a lot of cursing two weeks ago and stripped a nut on the strut tower (the one on the passenger side hardest to get to). Will have to find time to remove tht stripped nut to install it. :D
nooooooooo
jon, what did you do?
it took me 15 mins to install, and even less to uninstall!
3 bolts either side. drivers side was unobstructed, passenger side i removed one bolt to get a hose out of the way..
https://www.sau.com.au/forums/topic/242485-v35-strut-bar/#findComment-4233680
Sorry to disappoint...installed it today on the 300GT, so the wife can have increased handling when bringing the groceries home :P
Removing the 3 bolts each side was easy this time round, but getting the damn thing on the passenger side was a bit of a pain. Warren, I had to change the settings a bit from yours as I believe the coupe and sedan may be slightly different. No way they were gonna fit with your settings.
https://www.sau.com.au/forums/topic/242485-v35-strut-bar/#findComment-4235480
ahh...jealous jealous~
it looks nice. but do you have to take the engine cover off? hey. where did u get the bar? i soooo wanna hav one on my coupe~ lol :P
Sorry to disappoint...installed it today on the 300GT, so the wife can have increased handling when bringing the groceries home :laugh:
https://www.sau.com.au/forums/topic/242485-v35-strut-bar/#findComment-4235528
hey Fox'
If you are interested you can get one from USA like the NRG brand. They are made to fit with the stock Engine cover and the cheapest one. I got one quoted US$225 shipped from USA.
So maybe a group buy? lol.
Edited by pw350gt
https://www.sau.com.au/forums/topic/242485-v35-strut-bar/#findComment-4235683
haha~ good idea~!
but i think the NRG brand only has 2 bolts either side, (not sure) lol~is there any other brands you know? if we group buy maybe should get a better one~ lol :P i saw a GT SPEC one on US ebay, but im not sure if it will fit the stock engine cover, and not sure if it's better~ lol.
btw. where r u? haha
hey Fox'
https://www.sau.com.au/forums/topic/242485-v35-strut-bar/#findComment-4235779
I'm in Melb.
The other brand i know is ARC. I read the people in US really swears that the NRG are good. but i don't know.
I just don't justify to spend a Sturt bar for nearly AU$500 unless we as Whiteline to make one for us.
https://www.sau.com.au/forums/topic/242485-v35-strut-bar/#findComment-4235891
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
