My R33 is blowing white smoke when i hit boost.. only when i hit boost. i already got my turbo re-build by gcg turbos.. now its a ball bearing high flow turbo.. im running 10 psi have a boost controller, after market exhaust and thats about it.. everything i have read says turbo seal or head gasket or whatever... what should i do.. i have to drive to canberra 2moz but having 2nd thoughts now.. anyone out there know what i can do??
Take the car to a mechanic and have them do a compression and leakdown test. If that passes then you have most likely got a faulty turbo on your hand.
Not surprising due to all the chinese copy covers that GCG are using on their Garrett units now to save a buck.
it got sent over to gcg turbos and they said it would be a 3-4 day job.. didnt get it back for 2 and a half weeks... my mate called them and abused them saying that he would never go to them again and the dude fixing the turbo had to do it on a friday night and we were thinking he may not have done a proper job cause we got the shits with him. its been in the car for about 2 months or so.. its been ok.. but now all this white smoke when i hit boost.. i just spent $3500 getting it upgraded and everything.. what a shit hey... and i dont even have anything realllly aftermarket.. what a joke i have on my hands.. and i think its also out of warranty
fark me! for 3.5k you could have gone GT3076 with external gate inc. fitting etc. IT would make way more than a highflow
i get my car fixed from the place where i bought it in sydney cause my dad knows the owners and they recon they give me a good deal on everything i get done there.. i got $3500 off the asking proce for the car but whave really had nothing but problems since i put the boost controller on there.. thats bout the only thing that has made the car have problems and im only running 10 pound..
hey bud... u say its been having probs only after you put on the boost controller... are you sure its running 10psi? had it on a dyno? have u got a guage to tell you roughly how much boost?
what sort of boost controller? electronic or bleed valve?... u never know properly unless you dyno the car with those little aluminium key adjusting valves.
"never know properly unless you dyno the car with those little aluminium key adjusting valves" ... huh...? lol :O
Get a decent tuner (ie. not your dads mate!) to take a look. white smoke = bad news... oil is burning, so you've lost a seal somewhere. Turbo is most likely, but it could be a few things..
Found out what the problem is.. piston no. 5 is blown.. so i have to get a new block for the car.. when the turbo blew the first time some of the impella got caught inside the intercooler and now shreaded the piston ring... fun times ahead!
I got same problem as jazzathejerm's on my R33 RB25 det . Blowing white smoke when hit boost. Just few days ago, it was blowing oil from BOV. most likely Turbo's problem, i booked a engine compression test on this Friday and see how that go. if that pass, i go for the turbo upgrade. AS 3lit3 says GT3076 is a very good option, and KKR 430 or KKR 480 can be a cheap and nice option too.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
