TD06 20g L2 Turbo Kit suit RB20/RB25, includes: Turbo, Trust Manifold, Trust Wastegate, All braided oil and boost lines, Dump pipe, Inlet and Outlet pipes. Excellent condition. $2700
Apexi Power FC and Hand Controller to suit R32/33 GTR RB26DETT. $800
GReddy 300x600x100mm thick intercooler suit BIG hp applications, this thing is huge and in excellent condition. $800
17x7 +35 and 17x9 +17 Rims, 5 stud. $900. Will seperate rears for $650.
I'm not sure but everything else on the car, gauges, suspension, oil cooler all looked very new. With the yen how it is now these are well over $6000 brand new.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
