Running into some cash problems and thinking about selling the wheels that are on the car .
Just after some EOI at this stage .
The wheels are located and in sydney and have tyres yoko ecos 245/35/19 front and yoko ecos 275/35/19 rear. The tyres on the rear are 90% new and the front ones will need replacing . I believe the front are 19 x 8.5 and the rear 19 x 9.5 . Im not sure whats the offset but its off a v35 skyline 2003 with the brembo brakes as seen in the photo.
https://www.sau.com.au/forums/topic/243351-advan-conniosseur-151c-wheels/
here is a link if anyone is curious .
http://www.vividracing.com/catalog/advan-c..._4544_4572.html
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
