Hey guys just wondering how to peeps get to the stock water line at the back on the engine? like how do u replace it? or even undo it? without taking engine out?
Cheers
CHi
its located on the plenum at the back of the engine, you will need to remove the aac valve and move some wires out of the way. you will see a little 90deg rubber house connecting to the plenum, that will be it. you can reach it with a long set of pliers and disconnect it.
what’s even more difficult, it's also bolted down by a bracket right at the back of the engine near the gearbox, i just broke mine because i was replacing the whole line anyway but it’s a !@#$ to unbolt that little bracket. good luck! :cheers:
cheers!
:D
I don't like chopping and brazing the stock line, but some do it.
Hell, some even just use an olive fitting screwed on.
Some even more ghetto people just use a piece of rubber hose to join it.
The way I like to do it is to take the stock line off, wraps around the back of the block, and have a braided line made up for the whole way.
Behind the block on the stock line is a little rubber hose joiner - being 10+ years old, it is likely perished or about to leak. If you do it right now, it will save having to take the line out later.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
