Hey all,
don't know if anyone has experienced this one before.... I've got a bleed valve on it to bring it up to about 10PSI but through the rev range it only hits to 10psi after it revs past 4000rpm. anything below that, its still at the stock 7psi. Can anyone help with any 'constructive' :D suggestions to fix this problem???
https://www.sau.com.au/forums/topic/24391-boost-issues/
Bleed valve is a cheap way to increase your boost, but not as reliable as Electronic Boost Controller one. solution perhaps is to get a proper electronic boost controller like Apex'i AVC-R or HKS EVC.
I have a bleed valve as well, still saving money to get an EBC.
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-520586
for $135 you can get the Turbo XS High Performance Boost Controller (HPBC)
it has 2 adjustments.
1 = increase boost
2 = reduce or eliminate wastegate creep.
the second adjustment is what makes the boost come on earlier and harder.
R33's standard boost is 7psi.
R32 is more like 9 or 10psi standard.
as mentioned, if you put a boost controller on, you need to use that INSTEAD of the standard boost solenoid...
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-522609
Originally posted by Hicks
Probably because the stock turbo cant make more than 7 pounds of boost below 4000 revs.
i doubt it as the r33 series 2 spools up real quick coz of the plastic comp wheel.
at the moment with my half complete project i can get 12psi boost at just under 2000rpm with lightened flywheel, adj cam gear and pfc tune.
Legend
I think you have your stock boost solenoid still connected in the line. Bleed valves are cheap and nasty, dont ever expect good boost control with them.
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-523152
Originally posted by legend
INASNT: me thinks I'm going to have to invest in an EBC...:) $$$
predator666: nope, got a greddy boost gauge :)
yes you better. I think my greddy profec b spec 2 also helps bring boost on early!! Only think with the spec 2 is that you have to *** around with it alot to get it to work the way you want
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-524336
yer.. with my profec it comes on at about full boost at about 3500rpm from what i remember.. not bad considering just S-AFC, zortst, cooler combo. it'll make a difference..
really depends on the bleed valve.. some are worse than others..
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-525744
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
