std gtst R33 wing with brand new brake like ($300 was paid for the tail light genuine nissan) - $150
Drift D1 seat for drivers side on R33 rail as new condition - $250
RB25 turbo on manifold with oil feed - $350
RB25 block with good crank and rods. has 3 broken pistons - make an offer
S13 SR20DET front disks and calapers. disks only been on for 5 to 10,000 k's. calapers have bendix metal pads about %50 meat left - $200
S13 brake master - $50
S13 brake booster - $30
i dont get on the net much these days so sms or phone me on 0413595838 for anything urgent or for pics of anything
https://www.sau.com.au/forums/topic/244090-clean-out/
nah mate got the manifold.... i actually have 2 std manifolds
Interested in a manifold - but would like to inspect before buying (mine is cracked)
PM me with some contact details.
*edit* Just re-read your original post with & saw your mobile number...
I'll sms you shortly.
Edited by BensDR30
https://www.sau.com.au/forums/topic/244090-clean-out/#findComment-4296136
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
