hi guys i have to buy some new tyres . The size i have on at the moment is 245/35/19 front and 275/35/19 rear. The rears are good at this stage but i need to replace the front two.
What i wanted to know was from everyone's experience whats the best tyre they have found in regards to wear and performance. Im not after something that wears down by the day and incredible handling. I just want to hold a bit of grip in the dry and wet .
Also i have found a set cheap on ebay but the size is 235/45/19 will they fit without rubbing the guards. Does anyone else have this size tyre on . My car is factory height from what i can see .
Edited by manda23
https://www.sau.com.au/forums/topic/244308-tyre-size/
Check this website to see what size you need.
http://www.miata.net/garage/tirecalc.html
I think those 45 profile will throw your speedo out by too much.
Cliff
Thanks whats the stock tyre size for v35 coupe 2003. ?
What tyres have you found to be good value for money
https://www.sau.com.au/forums/topic/244308-tyre-size/#findComment-4254695
45 profile is for 18s, 19s you will have to step down to 40 or 35 depending on tyre width to keep the rolling diameter and speedo accurate.
A few good tyres I recommend which I have used:
1. Falken FK452
2. Sumitomo HTR-ZIII
3. Federal SS595
They are decent tyres with a good combination of grip and wear without blowing the budget. If the above is still not within budget then ur next step down are your Nangkangs, Maxxis and Nexens.
I normally use this calculator to work out tyre sizes. Stick in the factory specs eg: 225/45/18 and insert the possible tyre profiles in 19s which you are after. Rule of thumb is you should stay within 15mm of stock diameter.
https://www.sau.com.au/forums/topic/244308-tyre-size/#findComment-4254775
1. Falken FK452
3. Federal SS595
The ones im looking at buying is the pirelli p-zero 235/45/19 i can get them for $600 for the pair. Also the yokahama in 245/35/19 for $600 for the pair. Have you or anyone heard of a italian tyre starts with the letter M ?
How much is the falken's ?
https://www.sau.com.au/forums/topic/244308-tyre-size/#findComment-4254799
Falkens cost me just over $300 for 265 in 18s. Do not get the pirellis in the 235/45/19 as it is way out and you will probably start scrubbing...Tyre starting with M...Michelin?
i guess i will have to let me pirelli go then. And the tyre is not michelin something else. I saw alot of them listed on ebay before and now they are hard to find. I will try doing a search for them alot of people using them give them the thumbs up.
https://www.sau.com.au/forums/topic/244308-tyre-size/#findComment-4254841
yeh i think if anything the biggest profile you'll want to go is 40...judging by ur picture though 45's wouldn't look/be too bad...do the 245's stretch? what size is ur rim?...if 245's don't stretch on ur wheel u can get 235 but by the looks of it 245 should be the best choice.
https://www.sau.com.au/forums/topic/244308-tyre-size/#findComment-4254850
I have no idea what you mean by stretch . I dont know the size of the rim either . But a few people have said falken tyres seems to be ok for the money.
So you think the 235/45/19 would fit ok on these wheels
https://www.sau.com.au/forums/topic/244308-tyre-size/#findComment-4254956
1. Falken FK452
3. Federal SS595
+1 on the sumitomo HTRs. had them on my S15. nice in wet and nicer in the dry!
and thanks for that site Clikar23
https://www.sau.com.au/forums/topic/244308-tyre-size/#findComment-4254980
Im not really concerned that much about money value just handling and wear. I have never been a fan of falken . For some reason always like the brands like pirelli , michelin and yokohama.
Has anyone used the yokohama AVS im looking at getting a pair in 245/35/19 for $600 pretty good deal i think.
https://www.sau.com.au/forums/topic/244308-tyre-size/#findComment-4255006
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
