He's right it does work at low speeds. I think its called opposite phase or somethin at low speeds. It turns the wheels the opposite direction to the front wheels at low speeds. and at high speeds in turns them in the same direction as the front wheels.
Or if you don't enjoy unexpectedly being wrapped around a pole if you can't help booting it around corners. :)
It's not that it 'has a mind of its own' every time u boot it around corners. Sometimes it does it and you won't realise. But in my case when it swung me lane to lane, you obvs realise it and it becomes a hazard. I just got lucky, if it kept oversteering about 20cm more I woulda wound up over the box curb in the bushes. No point fitting it in after you crash it. Rather be safe than sorry imo.
Edited by Magic
it does work at low speeds because if i slow down for a turn and then gun it round the bend quickly it brings my back end round nicely, sometimes im not sure if it is the HICAS or me losing traction. i quite like it but then i have not had the car going hard round a track or a skid pan yet. am booked in to take it on the skid pan at AHG next month so i will have a better idea then and make my mind up wether i still like it.
That doesn't make sense.. HICAS would be working whether you gunned it or not (if it did in fact work at slow speed) and it wouldn't suddenly snap in when you apply the gas.. sudden dynamic steering changes mid corner upon application of accelerator? lolwut? do you have traction control on when doing this? Maybe it works differently on 34s? I'm still rather certain HICAS (at least in 32s) does nothing at low speed.
Found this, it pertains to HICAS in 240sx's.. can't be assed researching more right now.. so the question for now is: what is "moderate" speed?
Edited by bubba
Did some more research on it too and this website on the 240SX HICAS justifies mine, Ruckers and Steve's theory on it. And if it does this on the s13 it would no doubt have the same effect on 32s and above.
http://www.240edge.com/basics/super-hicas.html
Not sure how credible it is though. Would prefer to see pictures/info from Nissan itself.
I guess it doesn't really matter if it does/doesn't work at low speeds as its not really the issue. At the end of the day, lockbar is the go.
That image I posted above is from Nissan..
As for the speedo, it depends what has stopped working.. if it's the cable then no, HICAS won't work and neither will your speed sensitive steering. If the problem is after the cable (i.e. the speedo itself) then HICAS and speed sensitivy steering should still work (n.b. this only applies to S13/R32)
im having problems with my electric HICAS on my 33 ... it comes on after turning off the engine for a short while, im probably gonna
get a HICAS lockbar and lock the crap out of it !!!!! KYP in Wealshpool quote me 170 fitted .... is that an alright price ??
cheers
wtf? what makes you say HICAS is killing the engine?
that sounds pretty fkn strange..
no no .. nothing to do with killing the engine, just that when i drive around and i switch my car off for awhile ... when i come back and
switch the car back on the HICAS lights comes on and i lose the power steering.. LOL
Lol, thas kind of like mine atm.
I will be driving and the steering is a bit resistant then hicas light comes on and become some what hard to steer lol so
Im just getting the whole thing removed That way i save precious Kg's :D
It will all be fixed soon!!! ;)
ive teared it up @ ahg skid pan day and ive still got my hicas active. It didnt bother me too much tho. But then again it depends on what "high" speed and "moderate" speed is...
Top speed on a skid pan day if ur lucky is 100kmh.
Only to then slam the brakes and rip around the corner.
Booked in another one in dec... see how that one goes.
you doing it on the 14th of December? im booked in to do it then.
Don't you mean the 13th Dec? or is this not the SAUWA day?
If you mean the 13th like bubba said, then yep i am booked in then. The arvo session tho..
Nah sunday 14th not the SAUWA one. my parents got me it for my birthday. was ment to do it on the 16th of this month but coil packs went on me so had to move it to next month.
im having the same issues want to remove mine aswell,..to dangerous in the wet when sideways gets to unpredictable hicas gets confused..but i have a feeling that mine is affecting my powersteering as it gets really hard..almost like no powersteering at all..when car is just started in the morning the powersteering works fine but afta a while goes hard..has anyone else had this problem or could it be sum other electrical issues..
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
