I want to ride to my formal in style! As skylines have always been one of my fav's
Im after a r34 skyline inside the Adelaide Metro area!!
On the 27th of November between 6:30 and 7:30pm
Paid $100 cash to take me and my partner from Daw park to the Hyatt Regency on Noth Terrace int the city!!
Get back to me ASAP as i have left this very late.. Sorry bout that..
Email me on [email protected]
or on my mobile 0404859908
https://www.sau.com.au/forums/topic/245221-after-a-quick-100/
  • Replies 126
Posted Images
nobody likes 33s :)
i gota midnight blue 32gtr bathurst king come on people :(
well theres 2 offers and not 1 34 :D o wells im sure 1 of them will be able to help you out if not GTR = street cred
go everyone trying to get the $100 bucks like a flock of seagulls :banana:
Edited by Inline 6
*wonders why dan thinks his 32 is ''da shiz''
when there is other 32 GTR's/ Skylines on her a million times cleaner
and plenty people love 33s, well, those that have brains anyways.
:ph34r: :laughing-smiley-014: :laugh:
This was never meant to be a fighting ground....
i love all skylines!! but i just want a r34 coz ive never been in one...
and they look sick...
Love people... Show some love!!
Thanks for all the offers tho
I think ill just wait for some more offers
but ill keep you all in mind
