Originally posted by Ronin 09
Anyone had one fitted? What gains have you found? and how much would you expect it to cost?
cheers
I got a hks exhaust cam gear put on recently but with a whole bunch of other stuff so i couldnt tell u exactly how much ice charged me for it. Change your timing belt when u get it installed 2, if u already havent done so. We havent really played around with mine as yet because we are waiting for the new turb to go on. At the moment its set to -3 degrees i think.
(quick thread highjack)
SydneyKid - in your opinoin, is it worth while installing an adjustable exhaust cam gear when your still using the stock R33 GTS-t ECU ?
I think around -3 degrees is around the normal for the typical mods (boost/exhaust/FMIC). Does that sound right?
(/highjack off)
Hi Guys, for RB20 & RB26 we do both, commonly 1 degree advanced on the inlet and 4 degrees retarded on the exhaust. On RB25's with VVT, we only do exhaust with around 4 degrees retarded timing. We use Jun pulleys.
We have been finding lately that the good aftermarket camshafts actually don't benefit much from adjusting the camshaft timing. They are pretty much perfect with their "standard" timing. So if you are looking at doing camshafts (highly recommended on RB25's) don't bother doing pulleys.
I always recommend changing the ECU very early in the modification trail. Normally..........
1. turbo back exhaust
2. Upgrade fuel pump (on GTST's but not GTR's)
3. Boost up
4. Pod filter, heat shield & CAI
5. ECU
6. FMIC (on GTST's but not GTR's)
6. Turbo upgrade
7. Pulleys or camshafts (on GTST's, both on GTR's)
As you can see, pulleys are a fair way down the list.
Hope that makes sense
Sydneykid,
Should i spend $400 on the two pulleys? how much would appropriate cams on an rb20det with my setup cost? is it worth it?
Setup will include
RB20DET
Turbo Back Exaust
Custom plenum
PWR cooler
GTR injectors
Wolf 3d v4
Garrett GT28
Evan
Hi rb20-calais, used HKS 264's go for around $700, they work a treat in RB20's. As to whether they are worth it, well that really depends on your target power and what you are going to use the car for.
What I always suggest is to pick a power target and then match the components to that target. It is no good having a 220 rwkw turbo with a 330 rwkw intercooler, with 250 rwkw camshafts, with 200 rwkw injectors and a 290 rwkw fuel pump being stangled by a 170 rwkw exhaust.
Hope that helps lead to a conclusion
The problem I have had when modifying my car has been "at what point am I satisfied with the power". Its hard to know at what point, or hp, you will be satisfied with it as in the end you'll want more. And because you thought you'd be satisfied with the 320hp turbo, you'll find you will now have to sell it to buy the 450hp turbo, or the 550hp turbo and so it goes on. I'm not disagreeing with sydneykid, as I also believe you need to match as many parts to each other to get an overall excellent package, its just hard to know how much you want. I've got a turbo that will support 450-500hp, an intercooler that will support 500hp flow, but I find the turbo a little laggy and slow. I'm hoping with the new ecu and a HKS cam gear that will help the response. I may also look into the lightweight flywheel, lightweight pulleys (if anyone makes them) for better engine response and maybe some cams.
Also given time you get used to the power and generally want more :) I think that the best policy should be buy products with enough headroom should you want to upgrade to more power. ie: if I want more power now I just run more boost :) but I have to put other supports in place for that; ie pistons, bigger injectors. etc
Hi rob77, my answer was for an RB20DET in a Commondoor. An RB25DET in an R33 GTST is a totally different question.
Do you want to leave the internals of the engine standard or not!
If you do then answers are then very easy, everything needs to be set up for 450 bhp. Because that's the most you are going to reliably get out of an RB25DET with standard internals. So you use everything for that maximum, as you said if you don't want that much then turn the boost down. Simple.
If you want more than 450 bhp, then the question is again simple, how much money do you want to spend?
That's why RB engines are so great, there is enough information around to do whatever you want. You just have to ask the right questions.
Hope that clarifies
So back to the original question...
How much would it cost to have just the ex cam gear fitted and then set to -3 or -4 or whatever it is? (ie no dyno or ecu tuning).
No point getting an ex cam gear -yet- if its going to cost as much to get fitted as it will to buy it.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
