Ronin 09 Posted September 10, 2003 Share Posted September 10, 2003 Anyone had one fitted? What gains have you found? and how much would you expect it to cost? cheers Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/ Share on other sites More sharing options...
Guest INASNT Posted September 10, 2003 Share Posted September 10, 2003 Originally posted by Ronin 09 Anyone had one fitted? What gains have you found? and how much would you expect it to cost? cheers I got a hks exhaust cam gear put on recently but with a whole bunch of other stuff so i couldnt tell u exactly how much ice charged me for it. Change your timing belt when u get it installed 2, if u already havent done so. We havent really played around with mine as yet because we are waiting for the new turb to go on. At the moment its set to -3 degrees i think. Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-523135 Share on other sites More sharing options...
Sydneykid Posted September 10, 2003 Share Posted September 10, 2003 Fitting only or fitting and tuning? If tuning, what ECU? Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-523247 Share on other sites More sharing options...
Jay95R33 Posted September 10, 2003 Share Posted September 10, 2003 (quick thread highjack) SydneyKid - in your opinoin, is it worth while installing an adjustable exhaust cam gear when your still using the stock R33 GTS-t ECU ? I think around -3 degrees is around the normal for the typical mods (boost/exhaust/FMIC). Does that sound right? (/highjack off) Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-523285 Share on other sites More sharing options...
Ronin 09 Posted September 10, 2003 Author Share Posted September 10, 2003 nice jay, slipped that one in Will be at the same time as FMIC and EBC. Tune on dyno. Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-523349 Share on other sites More sharing options...
rb20-calais Posted September 10, 2003 Share Posted September 10, 2003 i also have this question. cost and best bet for the money when buying one. and cost of tune with wolf 3d v4, is it really worth getting an inlet one on an rb20 or just exaust? Evan Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-523363 Share on other sites More sharing options...
Jay95R33 Posted September 10, 2003 Share Posted September 10, 2003 Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-523395 Share on other sites More sharing options...
Sydneykid Posted September 10, 2003 Share Posted September 10, 2003 Hi Guys, for RB20 & RB26 we do both, commonly 1 degree advanced on the inlet and 4 degrees retarded on the exhaust. On RB25's with VVT, we only do exhaust with around 4 degrees retarded timing. We use Jun pulleys. We have been finding lately that the good aftermarket camshafts actually don't benefit much from adjusting the camshaft timing. They are pretty much perfect with their "standard" timing. So if you are looking at doing camshafts (highly recommended on RB25's) don't bother doing pulleys. I always recommend changing the ECU very early in the modification trail. Normally.......... 1. turbo back exhaust 2. Upgrade fuel pump (on GTST's but not GTR's) 3. Boost up 4. Pod filter, heat shield & CAI 5. ECU 6. FMIC (on GTST's but not GTR's) 6. Turbo upgrade 7. Pulleys or camshafts (on GTST's, both on GTR's) As you can see, pulleys are a fair way down the list. Hope that makes sense Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-523525 Share on other sites More sharing options...
rb20-calais Posted September 10, 2003 Share Posted September 10, 2003 Sydneykid, Should i spend $400 on the two pulleys? how much would appropriate cams on an rb20det with my setup cost? is it worth it? Setup will include RB20DET Turbo Back Exaust Custom plenum PWR cooler GTR injectors Wolf 3d v4 Garrett GT28 Evan Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-523696 Share on other sites More sharing options...
Sydneykid Posted September 11, 2003 Share Posted September 11, 2003 Hi rb20-calais, used HKS 264's go for around $700, they work a treat in RB20's. As to whether they are worth it, well that really depends on your target power and what you are going to use the car for. What I always suggest is to pick a power target and then match the components to that target. It is no good having a 220 rwkw turbo with a 330 rwkw intercooler, with 250 rwkw camshafts, with 200 rwkw injectors and a 290 rwkw fuel pump being stangled by a 170 rwkw exhaust. Hope that helps lead to a conclusion Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-524439 Share on other sites More sharing options...
rob77 Posted September 11, 2003 Share Posted September 11, 2003 The problem I have had when modifying my car has been "at what point am I satisfied with the power". Its hard to know at what point, or hp, you will be satisfied with it as in the end you'll want more. And because you thought you'd be satisfied with the 320hp turbo, you'll find you will now have to sell it to buy the 450hp turbo, or the 550hp turbo and so it goes on. I'm not disagreeing with sydneykid, as I also believe you need to match as many parts to each other to get an overall excellent package, its just hard to know how much you want. I've got a turbo that will support 450-500hp, an intercooler that will support 500hp flow, but I find the turbo a little laggy and slow. I'm hoping with the new ecu and a HKS cam gear that will help the response. I may also look into the lightweight flywheel, lightweight pulleys (if anyone makes them) for better engine response and maybe some cams. Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-524488 Share on other sites More sharing options...
rob77 Posted September 11, 2003 Share Posted September 11, 2003 Also given time you get used to the power and generally want more I think that the best policy should be buy products with enough headroom should you want to upgrade to more power. ie: if I want more power now I just run more boost but I have to put other supports in place for that; ie pistons, bigger injectors. etc Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-524490 Share on other sites More sharing options...
Sydneykid Posted September 11, 2003 Share Posted September 11, 2003 Hi rob77, my answer was for an RB20DET in a Commondoor. An RB25DET in an R33 GTST is a totally different question. Do you want to leave the internals of the engine standard or not! If you do then answers are then very easy, everything needs to be set up for 450 bhp. Because that's the most you are going to reliably get out of an RB25DET with standard internals. So you use everything for that maximum, as you said if you don't want that much then turn the boost down. Simple. If you want more than 450 bhp, then the question is again simple, how much money do you want to spend? That's why RB engines are so great, there is enough information around to do whatever you want. You just have to ask the right questions. Hope that clarifies Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-524535 Share on other sites More sharing options...
rob77 Posted September 11, 2003 Share Posted September 11, 2003 450bhp @ the engine? I assume it is. I plan to have about 370hp at around the 1bar mark on my turbo and it'll stay like that till I do pistons. Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-524584 Share on other sites More sharing options...
HKSgtst Posted September 11, 2003 Share Posted September 11, 2003 sydneykid, how much HP increase if i change the camshafts in my RB25det ? thanks ! Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-524676 Share on other sites More sharing options...
benm Posted September 11, 2003 Share Posted September 11, 2003 So back to the original question... How much would it cost to have just the ex cam gear fitted and then set to -3 or -4 or whatever it is? (ie no dyno or ecu tuning). No point getting an ex cam gear -yet- if its going to cost as much to get fitted as it will to buy it. Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-524679 Share on other sites More sharing options...
Ronin 09 Posted September 11, 2003 Author Share Posted September 11, 2003 yes, i don't think this has been answered yet... but all the discussion has been very welcome and informative Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-524721 Share on other sites More sharing options...
BOOSTD Posted September 11, 2003 Share Posted September 11, 2003 My cam gear cost $80, is a no name brand and made an extra 13kw at -4degrees. Noticable reduction in spool-up time- maybe 100-200rpm. Exhaust note is louder at low revs to. Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-524894 Share on other sites More sharing options...
BOOSTD Posted September 11, 2003 Share Posted September 11, 2003 oh and -4 degrees equates to ~1.9mm on a cam gear with no marks. Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-524900 Share on other sites More sharing options...
Jay95R33 Posted September 11, 2003 Share Posted September 11, 2003 Originally posted by BOOSTD My cam gear cost $80, is a no name brand DAMN !! Where did you pick it up from for that price? Link to comment https://www.sau.com.au/forums/topic/24528-approx-cost-to-fit-adjustable-exhaust-cam-wheel/#findComment-525005 Share on other sites More sharing options...
