Guest RedLineGTR
what about cam shafts...i hear thier are two types of lilke HKS ones...one for top end one for bottom end..is it true that u get a different exahust note? and how much power extra would you get on a mild mod setup. Would it make much diff? or would it make it worth while when high HP applications are in use...
Well Sydneykid comes up with the goods YET AGAIN!
What he says seems to gel with what I'm hearing.
Aftermarket cams be they HKS, Tomei, Jun etc. usually have everything dialed spot on.
Drop them in. Instant power in the middle.
But $200 - $300 sounds like a good deal for an alleged 10-15kW.
But like all timing improvements, it's more FEEL rather than numbers.
T.
Jay: D1Garage here in Adelaide.
Everyone- Cam gears are very easy to fit, do it urselves. I paid $70 for dyno time/tune. Found that -4 degress is pretty spot on so I wouldn't bother getting it done on the dyno. However every car is different, lets just say if -4 degress gives you a very noticable difference, leave it were it is! The difference to me is like how the car runs on a cold day compared to hot.
Sorry Benm, I dont know how much it would cost. Why not give it a go your self? Couldnt be more than a 1 hour job to fit? BOOSTD? so on standard mech rates around $50-$70. Its seems pretty common, with stock cams to set up R33 to -4deg exh side.
Rob77, it was a second hand one from Japan that James picked up when he was over there.
they also have a set of 2 second hand if anyone is chasing more. think they are asking around $150 for both.
I was looking at this as a way to gain earlier boosting, and more low/mid range, but was put off when I was quoted "5 hours tuning to get it right!!!" all up the workshop wanted $1100 fitted and supplied.
I left it for a later date
Ned
Hi Ned, 5 hours is about right if you change the cambelt at the same time, which is not such a bad idea if you have more than 50K on the current belt.
Even without changing the cambelt, but still changing 2 pulleys and tuning from scratch, 5 hours is again about right. But with the help of the guys on this forum you can cut that down. Tell them to start at 1 degree advanced on the inlet cam and 4 degrees retarded on the exhaust. Then add advance to the exhaust cam in 1 degree increments until you have stiffened up the midrange (I work in 500 rpm increments from 3,000 rpm to 5,500 rpm) but not gone below the max power you previously had (without adjustment).
Once you have done that then sneak some more ignition advance into it, it should take 2 or 3 more degrees before pinging. Then they may be able to take some fuel out of it, not much though. I don't go below 12 to 1 A/F ratio on the F & W lambda, that's a safe place to be. You shoud see may 10 to15 rwkw increase in the max power but sometimes as much as 25 rwkw in the midrange.
As you can see if you want a good full rpm tune, it does take time. If you just want max power at one rpm point to brag about, then that takes a lot less time.
Hope that helps.
Originally posted by RedLineGTR
Sydney kid what about cam shafts...would there be any point in using them in a mild tuning application....
wouldnt bother rob unless u r going bigger turbo, new head gasket to lower the compression and running lots of boost
Hi Sydneykid,
thanks for the detail. I guess I had the idea that there was a bit of a sweet spot that could be dialled in (the +2, -4 degrees I hear regularly), with maybe another hour of fine tuning. BUt obviously its more involved than that.
Since you mentioned that the AFR's will help here as well, I guess that means that it would be best to wait until you also get an Emanage / SAFC / PFC to really optimise it?
I was trying to chart my own route to better low/mid range by doing front pipes / cam gears, and leaving the exhaust and ecu stealth style.
Ned
i have an HKS cam gear for my exh for my RB25
got a quote on fitting it from tilbrooks, but unfortunately this includes water pump, fitting/labour etc, so im not sure on cost of gear fitting only, but all up they quoted me $450 and 5hrs to fit the pump and set up the gear.
to tune my power FC they quoted me $250, which seems cheap to me? i expected around the 400 mark. How much has an ecu tune cost the rest of you?
It depends.
How long is the proverbial piece of string?
For me, the final dyno tune is just to cement AFR, Lambda etc.
The road tune should get 95% of the way there.
So I've been quoted 1 to 2 hours dyno time.
And that's an avg. $100 - $200.
If it was a PowerFC tune from baseline, we could be here for quite a while.
T.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
