hey i just got me a bov and was wondering what to adjust it to. it has a screw on it but im not sure what the difference between adjusting it to, to me loosening it make a hissing noise.
also when installed i rev it and hear 1 or 2 flutters from my pod but the bov opens at the same time. i know it opens coz i can feel the air on my hand [self reved from the engine bay]
thanks
also i have searched and after a reading "bovs are gay and blah blah blah" cant really find this info.
https://www.sau.com.au/forums/topic/245430-hks-ssq-adjustment/
If it's a genuine HKS SSQV it doesn't have an adjusting screw in it as it's not required.
Cheers
Marty
only the new ones have no screw..the older ones do have a screw
turning it clockwise will set it harder and anti clockwise will set it softer...the more boost your running the harder you set it
i installed a new one and it would stay open for too long and lag my turbo heaps... the older ones must have been heaps better with the adjusting screws..
Care to explain this as by design it can't happen.
It has a spring to hold it closed under light vacuum and only opens under high vacuum from the manifold. So as soon as you start opening the throttle again it is closed. It shouldn't have anything to do with making the turbo's laggy. If the BOV vents while boosting there is deffinately something wrong.
Cheers
Marty
Cheers
Marty
I bet you he will tell you its between gears lag,
I fitted a new HKS to a customers S14 SR20DET / T04z, from working perfectly with his old $20 knock off it started to fall right out of boost between gears unless I flat shifted with the HKS, it was replaced with a another unit, same problem....ripped the HKS out and fitted a Greddy RS and presto, no more problems.
so your saying that a BOV that releases the pressure inside the the inlet piping on gear change isnt working correctly?
since thats exactly what they are designed to do im not sure where the issue is, there should be lag from a system running a BOV as the turbo re-pressurises the piping.
Cheers
Marty
Well personally I don't think the new SSQs work well under high boost pressure.
With my current setup i have a HKS 2530kai and im running over 20psi with supporting mods. When i run that much boost with the SSQ it would stay open for a second or two after gear change, and the air would go into atmo instead of back into the plenum..
I'm not sure as to why this happened (too much vaccum under high boost pressure for the SSQ to handle?), but it only happened with the SSQ and not with any other atmo bov that I owned.
I've installed many atmo bovs and they all lagged my turbo in between gear changes (this is normal with atmo bovs).
Oh and I wouldn't have bought a bov if I intended on flat shifting 24/7.
Edited by EVL-R33
Craved, I am quite aware of how a bov works, as I said, lag between gears on the new SSQV was terrible compared to the RS, obviously the SSQV is prone to staying open longer or has slower/buffered piston movement than other name brand bov's.
EVL-R33
This is exactly what I am talking about, the SR20 in question was running close to 28psi and had an actual delay when shifting, knocks all the power out for a second or two like the bov doesnt close properly of fast enough,,, rip SSQV out and put in Greddy RS and presto no more problem... just regular minimal lag one expects from an abov...
has nothing to do with MAF either, all the cars I do now run VEMS or D-jetro.
In my opinion besides sounding retarded and looking gimiky the SSQV is just an expencive POS. Greddy, Tial or Synapse any day of the week for actual function which is what its there for.
Edited by Rezlo
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
