i dunno if its the same problem but mine made a churning noise on full lock and progressively startedd getting worse
i was told it was my power steering fluid... topped that up and it was fine...
probably unrelated to yr issue i'd say
https://www.sau.com.au/forums/topic/245525-turning-noise/#findComment-4272844
You say that your Dad checked them and they looked fine...
What exactly did he do to check them??
Its not normally something that you can see when they bugger up.
Is the noise the same both directions ie: left and right??
Is it more noticeable turning in one direction?
Does it get worse with a bit more speed on board?
Does it do it going in reverse?
https://www.sau.com.au/forums/topic/245525-turning-noise/#findComment-4276029
not in reverse
u turns are when it does it
dosnt matter witch direction
he jacked the whole car up and took all the rims off then f*k knows what he was looking at lol he checked the bearings aswell took the rotors off he looked at everything and couldnt find anything wrong and its got him stumpted
https://www.sau.com.au/forums/topic/245525-turning-noise/#findComment-4276171
CV Joints are not the kind of thing you can diagnose by looking at them. Especially if the boots are still intact.
It does sound a lot like the issue though. If it goes click click click while turning sharply and then goes away when straightening up I would be getting it looked at by a mechanic in your area.
But that's just me...
https://www.sau.com.au/forums/topic/245525-turning-noise/#findComment-4276314
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
