As the title says,
I'm after a pair of those little factory fitment rear mud flaps that come out on the R32 GTS-T's. I would prefer black ones if available.
Send me a PM if you've got a pair.
Cheers :/
Scott.
https://www.sau.com.au/forums/topic/24589-rear-mud-flaps-r32-gts-t/
WHITE R32,
I don't have a pic of them but I know what they look like ;)
It's not really even fair to call them mud flaps considering they're so little. I'm guessing we're talking about the same ones.
They're quite small and mould to the rear gaurds bolting up with the two 10mm screws on the rear of the gaurd.
Do you have a pic of your ones ?
i dunno what they are worth mate... but i dont think they are really easy to come by cause i havent seen em on many cars....make me an offer keeping in mind they would cost bugger all to send cause they weigh nothing...
I'm not really sure what they're worth but I know if any of my mayes got a pair ( they import cars ) they'd cost me a case :D
If they're in very good condition I'll give ya $100 for the pair delivered. How's that ?
how about ill send em to u cod for $50 plus postage man... they are good no cracks etc but they need a clean up they have normal wear as u would expect from something that sits behind a wheel all day lol.... in general a 8-9 out of 10 .... if u agree and it all sounds good pm me ur full address and mobile number and ill send em off to u straight away....
WHITE 32,
Yes thanks, still after them. Just never got a message that you'd responded. Just tried to PM you but your mailbox is full.
Give me a call if you want and I'll give you the details.
Scott 0414-862-626
Thanks.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
