As the title says,
I'm after a pair of those little factory fitment rear mud flaps that come out on the R32 GTS-T's. I would prefer black ones if available.
Send me a PM if you've got a pair.
Cheers :/
Scott.
https://www.sau.com.au/forums/topic/24589-rear-mud-flaps-r32-gts-t/
WHITE R32,
I don't have a pic of them but I know what they look like ;)
It's not really even fair to call them mud flaps considering they're so little. I'm guessing we're talking about the same ones.
They're quite small and mould to the rear gaurds bolting up with the two 10mm screws on the rear of the gaurd.
Do you have a pic of your ones ?
i dunno what they are worth mate... but i dont think they are really easy to come by cause i havent seen em on many cars....make me an offer keeping in mind they would cost bugger all to send cause they weigh nothing...
I'm not really sure what they're worth but I know if any of my mayes got a pair ( they import cars ) they'd cost me a case :D
If they're in very good condition I'll give ya $100 for the pair delivered. How's that ?
how about ill send em to u cod for $50 plus postage man... they are good no cracks etc but they need a clean up they have normal wear as u would expect from something that sits behind a wheel all day lol.... in general a 8-9 out of 10 .... if u agree and it all sounds good pm me ur full address and mobile number and ill send em off to u straight away....
WHITE 32,
Yes thanks, still after them. Just never got a message that you'd responded. Just tried to PM you but your mailbox is full.
Give me a call if you want and I'll give you the details.
Scott 0414-862-626
Thanks.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
