Hey guys Im thinking of adding a Front Mount Intercooler to my R34 Gtt ive been looking on just jap and ive seen two types one where the pipes both go down to the right of the engine bay then goes behingd the cooler and has like a 180 degree bend to the left of the cooler and the other type is the normal one where the pipes go down both sides of the cooler
whats the differecne between to two? and does brands matter
please lets me know
thanks guys
Jason
https://www.sau.com.au/forums/topic/245934-intercoolers/
Any pics?
This is mine, from just jap.
the other one Im thinking of has the return pipe away from engine (opposite to mine)
and uses the stock intercooler pipes and holes near the airbox
https://www.sau.com.au/forums/topic/245934-intercoolers/#findComment-4276963
Any pics?
yeah it does
whats the difference?
https://www.sau.com.au/forums/topic/245934-intercoolers/#findComment-4277415
The Stealth type runs the return pipe underneath the intercooler, no drilling or cutting required, i'd assume that it will breath better, as it has less bents and a shorter pipe then the original tube n fin type.
I've the tube n fin type, my return pipe runs across the above of the engine bay, and back to the throttle body, same as Evil's.
As for brands, it doesnt really matter unless you are chasing massive power, jap just kits can handle up to 300rkw+ with proper mods.
https://www.sau.com.au/forums/topic/245934-intercoolers/#findComment-4277630
Also is there much mucking around with the traditional type of intercoolers, i have heard that people have to move the battery, modify air boxes etc?
No, there is no need to move the battery.
There shouldn't be any modification to the stock air box, it should be straight bolt off + bolt on.
https://www.sau.com.au/forums/topic/245934-intercoolers/#findComment-4277846
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
