whats up everyone. my first post, a question, dont you have people like me.
anyways.
ive got an a31, and ive seen them with r32 front ends before, i think its pretty cool, just lookin for information on it, does it bolt up? whats neccesary? etc etc, any insight is appreciated, thanks
https://www.sau.com.au/forums/topic/246750-r32-front-end-on-a31/
yep it is a 32 front on a cefi, even says by his own confession that it was sloppy fitting as the bonnet doesn't align quite right... Why don't you find out who owns it and email him the question....
As far as Nissans go, most parts fit most cars. So it shouldnt be a nightmare to fit up, however it most likely wont be easy. You will need the headlights, bonnet, front bar, reo bar, and custom fenders. The bonnet catch most likely wont match up so you will need to customise that, the bonnet hinges MAY need customising. As for everything else, new holes may need drilling. The best thing to do would be to take a tape measure and measure up all these things between the two cars to see if its plausable.
Good luck!
Edited by NA_Goodness
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
