whats up everyone. my first post, a question, dont you have people like me.
anyways.
ive got an a31, and ive seen them with r32 front ends before, i think its pretty cool, just lookin for information on it, does it bolt up? whats neccesary? etc etc, any insight is appreciated, thanks
https://www.sau.com.au/forums/topic/246750-r32-front-end-on-a31/
yep it is a 32 front on a cefi, even says by his own confession that it was sloppy fitting as the bonnet doesn't align quite right... Why don't you find out who owns it and email him the question....
As far as Nissans go, most parts fit most cars. So it shouldnt be a nightmare to fit up, however it most likely wont be easy. You will need the headlights, bonnet, front bar, reo bar, and custom fenders. The bonnet catch most likely wont match up so you will need to customise that, the bonnet hinges MAY need customising. As for everything else, new holes may need drilling. The best thing to do would be to take a tape measure and measure up all these things between the two cars to see if its plausable.
Good luck!
Edited by NA_Goodness
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
