  • Replies 101
okies more parts to be added to the list for sale:
Item: 2x R33 Skyline GTS Front Brake Calipers
Item Condition: used, great condition, worked perfectly, plenty of meat on pads, good condition pots etc, will fit on silvia's, ALL skylines (turbo and non turbo), also have rotors for sale here to match!
Price: $100.00ono
Item: 2x R33 Skyline GTS Front Brake Rotors (4-stud 4 x 114.3)
Item Condition: used, plently of meat left (will fit on silvia's, 180's etc)
Price: $30 each or $50 for both!
Item: 2x R32/3 Skyline GTS-T Front Brake Metal hard lines with brakets for hubs
Item Condition: used, comes with olive fittings, bolts and braket, ready to use in any brake set up (hard lines are better than rubber!!
Price: $30
Item: 1x R33 Skyline Front Sway Bar
Item Condition: used, but perfect, with mounts
Price: $20.00
hey mate the r33 front brakes how much to ship to newcastle nsw 2304?
cheers chris
PM SENT
Also: r33 thermo fan sold and r33 i/c compressor pipe
do you have any 4door 32 power window regs mainly after rear right,
Hey mate only have an r32 wrecking so they may fit still!?
Hame!
couple of parts till available that people said they wanted but never followed through: DRIFT pod filter & adaptor, r33 GTS-T fuel pump (ready to drop in), Neon lighting.
Offers will be considered on most parts!!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
