R32/r33 Greddy Alloy Intake Pipe, Fuel Pressure Regulator, R33/s14 Castor Rods, R33 Jap Exhaust 3"--> 3.5" Massive Tip!
Location: Adelaide , SA - Contact: - PM or SMS 0404998591
Got the following items that are no longer needed:
R32/R33 Alloy Intake Pipe complete with silicon hoses connectors, clamps etc - was told it was Greddy when purchased but has no signs of branding. This pipe sounds incredible when spooling and boosting really has to be heard to appreciate makes driving much more fun! A alloy intake pipe is essential for those running more boost than stock as the soft stock rubber hose starts to become a restriction and suck in.
The pipe has a BOV return and oil breather ports just like the stock rubber hose but also has a port for a intake air temp sensor (one is currently fitted) perfect for those who wish to monitor intake temps or run a MAP sensor based aftermarket computer like WOLF 3D, Haltech etc. The pipe is tapered gradually expanding from the stock turbo inlet to the AFM size which not only looks tuff but improves induction.
Price - $175
Monza M-Spec Fuel Pressure Regulator complete in box with gauge, hoses & fittings bought from Repco for $150. Price - $75 $60 FIRM
S14/R33 Castor Rods complete with all nuts and bolts required for fitting. Rods are in good condition with no sign of leaking from the bushes. Price - $50 pair
Innovate Motorsports LM-1 Wideband Kit complete with optional RPM Converter Kit to allow mapping of RPM/AFR. Cost over $700 new and used twice still complete in box. Price - $450
Z32 AFM Plug complete with clip, loom and installation instuctions for SR, CA and RB powered cars. - Price - $20
Japanese Fujitsubo Giken FGK Super High Flow Cat Back System to suit R33 GTS-t,
First up is my Japanese Fujitsubo Giken FGK Super High Flow Cat Back System to suit R33 GTS-t, will fit R34 with slight shortening and flange flipping round at cat end. This exhaust is extremely high flowing starting with 3" mandrel bend piping up to the flange and at this point the exhaust expands out to 3.5" piping all the way to the tuff cannon muffler with awesome tip. This makes clearance that bit better at the centre of the car for speed bumps etc whilst maintaining maximum flow.
I bought this system for $700 from local wreckers but then spent $200 on a new centre muffler as the old one had I small hole I didn't notice upon purchase for which I still have the receipt and warranty on that part. This exhaust is flanged in the centre making transportation a breeze I can undo the flange if required by buyer to make fitting into a normal car easier. Pics are below the black appearance to the lower half of the exhaust is from it being spray matt black so as not to draw attention from the cops I can remove the paint if required but I recommend it. Note silencer is not included in sale this was borrowed to clear defect.
Price - $400
R33 Viscous LSD Diff Complete in 4.1 Ratio NON-ABS Housing with 5 bolt half shafts in excellent condition with all ready to bolt in - Price - $200
Location - Adelaide , SA
Contact - PM or SMS 0404998591
Edited by nigelswazi
PRICE DROP ON SOME ITEMS AND 18" TYRE ADDED AS BELOW
Price - $175 Now $160
Pirelli P-Zero Rosso 245/40/18 Tyre with 95% tread no longer have 18" wheels so no need for this tyres which retails for over $400. Price - $75
Price - $400
Price - $175 Now SOLD
Pirelli P-Zero Rosso 245/40/18 Tyre with 95% tread no longer have 18" wheels so no need for this tyres which retails for over $400. Price - $75ono Now $50 FIRM
S14/R33 Castor Rods complete with all nuts and bolts required for fitting. Rods and bushes are in good condition with no sign of leaking from the bushes. Price - $50 pair
Price - $400 Now $375
Stock R33 Flywheel perfect for those looking for one to do a manual conversion - Price $75
R33 Series 2 Centre Console - Price $40
R33 Series 2 Drivers Window Switch with surround - Price - $60
EXHAUST NOW SOLD POST AMENDED AS BELOW
Price - $400 Now SOLD
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
