Hey guys, Wanted to add pics to my original post but for some reason i wasnt able so i started a new post.
I bought this car about 2 months ago, gave it a full rebuild but i now have a company car and no time to put the finishing touches on this.
Car has 145,000 kms on it, engine has 1000kms
1995 sports 200sx
5 speed manual
Brand new Exedy Heavy Duty clutch (1000kms old)
ARIAS forged pistons (1000kms old)
Big end, main & little end bearings (1000kms old)
Full gasket kit, replacing all seals (1000kms old)
ARP head studs
ARP main studs
Cometic multi-layer head gasket (1000kms old)
GT28rs turbo
850cc Injectors
550hp intank fuel pump
Power FC with hand controller
Turbosmart dual stage boost controller with rocket switch in cabin
Z32 AFM With brand new Apexi pod filter (250kms old)
Reco head (decked, valve guides) (1000kms old)
Brian Crower valve springs
Rocker Arm Stoppers
Genuine Hybrid 600x300 cooler with piping
3" exhaust with high flow cat
s13 Inlet cam gear
Engine Dampner
New water pump (1000kms old)
New fan belts (1000kms old)
Complete edge body kit
Currently have two sets of wheels, 18'' Zenetti teks or brand new 17x8 & 17x9 Lenso d1r in complete white (300kms old)
Pedders sports suspension all round
Momo Steering wheel
Trust gear knob
Autometer Boost Gauge
Greddy turbo timer
Alarm and immobiliser
Alpine cd player
10'' sub & amp in boot
Thats all i can think of for now if you have any questions pm me.
Exterior is factory red, in great nick with no major scratches or dings. Interior is standard besides listed mods and is in immaculate condition.
Car had 200kw's when i purchased it, now it has forgies in it, can run more boost. Just requires another tune and should see 220kw+
Looking for $16,500 with the zenettis & $17,000 with the lenso's.
Am open to swaps but for something practical i can use as a run around on the weekends.
Contact daniel
Phone: 0414 727 456
Email: [email protected]
https://www.sau.com.au/forums/topic/247269-95-s14-200sx/
  • 2 months later...
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
