Was asked to do this formal way back for a friend and had to pull out cos it's a bit much to drive all the way from Sydney for one night to do a formal.
So If anyone is capable of doing it for me (car up to the standard of mine :) lol jokes) can you let me know ASAP so i can pass your details on to my friend it's for her younger sister and at the moment she will be going in a bog stock 1998 Honda Accord.
You can't get better charity than this come on it's a honda
and I know $50 isn't great but hey I went on a putty road cruise for a few hours sunday and thats all I used in fuel well worth the $50 bucks might I say!!! :(
Cheers
https://www.sau.com.au/forums/topic/247497-urgent%E2%80%94you-get-50/
i could take her in the 323 then if you like shawn :rolleyes:
smart arse :)
probs just the one the chick isn't overly into cars just doesn't want to go in something like a honda lol
will let ya know though shortly
last time i do anything for you!
:rolleyes:
Remember this!!! :)
I'll clean my car tonight anyway, so if mccready, zcr and myself (whats wrong with yours mang) could give her a 3/4 car 32 convoy depending..... Maybe more
Depending on what time it is on cause i dont finish work till 6pm, I could do it in my black R32.
Could even get a silver R32 and gun-metal grey as well make a bit of a entrance.
Let me know buddy
i own the silver one he put on offer, and like he said, depending on time, let us know
Remember this!!! :rolleyes:
hahahaha
I can't believe you went back that far to find that, took me a while to figure out what it was from lol
I forgot i did that formal for you but it wasn't exactly much i drove from braddon servo to the museum and i was already in civc lol
Well this is starting to piss me off get asked to organise a car when my friend doesn't know any details except it starts at seven, no idea of pick up point but should still be enough time wont have conformation if the sister is happy with that and pick up time and place until around 9pm tonight
you's cool to find out that late if it's to much hassal thats cool.
You coming on the xmas cruise on the 21st turismo haven't even seen your new car yet mate
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
