Hi everyone
Looking to sell my 1996 Series 2 R33 Gts-T. I have priceD the vehicle well for what is in the market currently. I am after a reasonably quick sale but not giving it away. the reason for selling is the birth of my second child and it is a bit hard with a 2 door coupe to put in all the baby gear.
Phone: 0438538019
Rego: AZA 81E NSW rego til 20th April 2009
Mods
Turbo back exhaust with HKS super drager muffler
Hybrid FMIC (cooler and piping sprayed matt black for stealth)
K&N pod filter with enclosure
Turbosmart Plumb back BOV
Walbro fuel pump
Exedy cushion button clutch installed 20K kms ago
Gates timing belt installed 5K kms ago
Splitfire coil packs and NGK Iridium Plugs installed at 120K kms
18" Rims
Greddy full auto turbo timer
Front and Rear Strut braces
8000k HID low beam headlights
Kenwood 7" foldaway screen and DVD player KVT 745 rrp $1899
Kenwood P605ie splits front and rear rrp $229 set
Pioneer 4 ch amp
Wiring in boot for connection of amp and sub
Black widow alarm with remote central locking
5pcs Skyline floor mats
121073 kms
Parts that will come with the sale are
Factory series II spoiler
Factory air box and air filter
Trust foam filter
Factory fuel pump
Factory coilpacks
Fuel Pressure regulator
Adjustable cam gear
Lowered front springs
post-24862-1228290098_thumb.jpgpost-24862-1228290130_thumb.jpgpost-24862-1228290167_thumb.jpg
post-24862-1228290190_thumb.jpgpost-24862-1228290209_thumb.jpgpost-24862-1228290232_thumb.jpg
post-24862-1228290272_thumb.jpgpost-24862-1228290294_thumb.jpgpost-24862-1228290331_thumb.jpg
I welcome any feedback, comments or questions. Any inspection welcome or i can take to a mechanic of your choice for a independent inspection. Like i said i am negotiable on price so give me a call and we can discuss. This is a clean example of a lightly modified skyline. If you have any requests for a specific picture please ask i am more than happy to take addition pics.
Thanks Brad
Edited by neostagea
https://www.sau.com.au/forums/topic/247545-for-sale-r33-ser-ii-gts-t/
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
