R32 actuator sold.
ITEMS STILL UP FOR SALE: some items have price drop...
R33 S2 head lights - 700ono
R33 S2 Front bar with re-enforcement bar (see pic's) - 400ono
R33 GTR front sway bar - $100ono
R33 Stock actuator - $30
R33 Stock Turbo - $ 300
6x 480cc Injectors for RB25DET - side feed - $500
R32 Tanabe Shocks and RSR springs - $250ono
R33 OEM front springs and shocks - $200ono
Used 2 gauge piller pod for R33 - $35
R33 s2 spoiler white - $100
R33 factory front and dump - $60
R33 S2 front driver and passenger seats - $150
Stock R33 GTS25t BOV - $50
Stock R33 GTR BOV - $70
  • 4 months later...
Items still up up for sale...
-R33 S2 Front bar with re-enforcement bar (see pic's) - 400ono
-R33 Stock actuator - $30
-R32 Tanabe Shocks and RSR springs - $250ono
-R33 OEM front springs and shocks - $200ono
-R33 factory front and dump - $60
Price are negotiable...
That front bar is a type M, yes?
Comes with the indicators also, as well as reo bar?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
