Need To Borrow 32gtr Airpods For 5min Just To See If Mine
hey guys is there any1 that i can borrow there 32gtr podfilters from just for 5min to try them on my car to see if thats the cause of the problem? im located in dandy
u can sms me on 0422 607 113 thanks guys help much appreciated
how can pod filters be a problem for anything?
just take em off if you need to test, will work the same as swapping
i wana see if there 2 dirty and try another set to see if it makes a big difference
Unless they were so blocked up that air wasnt even going through them...
You wont really notice a difference.
Totally depends on what problem you have though, but ive never heard of a dirty pod seriously degrading performance
the problem is the revs drop really low sometimes and then back up feels like its gona stall and sometimes it does stall thought maybe not getting enough air.yer i think im gona give em a clean with compressor a bit.and im taking the car down to status tuning 2morow to get checked out so they should be able too tell me.
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
