Hi all.
Was just wondering if it's possible to fit a second amp under the passenger seat in my 33, there's lots of bumps and stuff under there and I'm rather dubious.... I've got one amp under the driver seat already, but want to leave it there, bridge it's channels to the fronts and then put in a second amp to run 2x 10's.
In particular, I'm looking at this amp in bridged mode to run the 10's.
Is it possible? If not, where are others putting second amps? I like my audio gear to be neatly hidden from sight, and I can't just sit an amp on the boot floor anyway, as I go to the track and also need to fit a large guitar amp in there (my sub enclosure is installed in such a way it can be removed/re-installed quickly).
Edited by sl33py
Hi all.
I've got two amps and lots of other goodies in the little compartment behind the rear seat... i.e. next to the battery and above the fuel-pump cover. Out of sight, doesn't take up any room (well, not that wasn't just wasted anyway), and wiring is fantastic (power direct from the battery, rear-speakers and sub are very close, just had to run new front speaker wires and in your case, RCA's to the HU).
I'm running a 'CarPuter' in there too, so I didn't need to run RCAs all the way up to the front of the car (had to run VGA and USB cables for the touch-screen instead :(), but I think it's a fantastic little spot for amps and other gear.
Interesting. Musta made it fun to tune the gain and crossovers :( I'll have a looksee tonight
Haha yeah it was a bit of a job... but I'm lucky coz the amps in the 'line have raised knobs for the tuning, you could just reach in and turn them as required. The one in the Lancer has kinda 'screw' ones u need a screwdriver to adjust... that would have made things pretty much impossible lol!
+1 for area behind rear seats
i made a bracket to hang down from the computer for the demister etc or whatever it does, so it just bolts on and hangs off that so I can take it off if one day i decide i want a different amp or something :P
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
