only a eoi at this stage, chances are i will keep it.
Make/Model: HR31 GTS 4 Door Hardtop
Year: 1985 - NO cat required :D
Kilometers: 201,000
Transmission type: Manual
Engine: Silvertop RB20DET 95 000km's ----> car is registered with this engine, nothing dodgey here.
Colour: White
Modifications:
Silvertop 20DET
RB25 Turbo
3" Custom Exhaust
FMIC custom piping
Oz 31 radiator
RB25 Clutch, Very good condition
R32 RB20DET Gearbox
very tight r200 LSD
Bosch 910 External Fuel Pump, good for atleast 350rwhp
Surge Tank, mounted under the car and painted black
Aftermarket Suspension, new KYB rear shocks (6months ago), lowered and stiffended springs
Adjustable Selby sway bars F+R
castor rod bushes just done
Noltec Solid Rear Subframe Bushes
GTSX Brakes, front pads just replaced
tires all 90%+
Turbotech Ball Bearing type boost controller
JVC MP3 deck, 6" speakers all round
Apexi Power Intake Pod
new SPARCO suede Racing Steering Wheel
Accident History: none
Asking Price: $6400
Contact Details: 0405 o6o 124 pm or Reply here
Other Comments:
Car was imported in 2001 by Steve May (maytech) & featured in HPI. Was tuned by Hyperdrive and made 248.4rwhp. Everything is in good condition and works. Interior is in very good condition. Body is in good condition. Air con has been converted to the new gas setup, just needs gas in it.
also has a set of new kyb front struts, still yet to be fitted.
will include the AEM WIDEBAND gauge which is fitted & working perfect (cost $400 for this alone)
car has no issues, does not leak any fluid (incl power steering), allways idles,runs & starts perfect.
does not use, leak or burn any oil.
I also have the following parts which may be availalible by negoitiation to buyer at a cost.
i am planning to fit these soon & if i do the asking price will be revised to suit.
brand new innovative t04e hybrid (genuine Garrett core - NOT china) rb20 bolt on turbo kit.
Z32 afm with plug
GTR injectors - just been flow tested, reconditioned & cleaned
GTR injector resistor pack
Apexi power fc with hand controller - includes tune to suit afm & injectors
again, this is only an eoi
pics:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
