I've got a full set of brakes from my GTR as I've just done the big brake upgrade. For sale is the following:
Sumitomo calipers - std GTR spec
Braided lines from the group buy - all by brand new
RDA slotted rotors - all but brand new
QFM K750 pads with a set of DS2500 pads - both sets, front and rear at least 90%
All bolts, and associated bits 'n' pieces
I'll throw in the original rotors which are all serviceable too. They were machined 2,000kms ago.
All in PERFECT working order.
These come off my immaculate GTR and you can be assured they will bolt on and work how you want them to.
I will post at at your expense. Located in Dandenong Victoria if you want to pic up. Pics later......
$1,000 the lot.
https://www.sau.com.au/forums/topic/248527-r32-gtr-brakes/
Bump for those who want to buy this set up 'whole'. I'll be in touch with those that want parts shortly if not sold 'whole'. Slow down for the New Year with my brakes.
https://www.sau.com.au/forums/topic/248527-r32-gtr-brakes/#findComment-4338311
will these bold onto R34 GTT???
are these also like brembos where different offset wheels are needed???
also are these classified as standered nissan brakes that i would have on my GTT seeing as these arnt brembos??? also in rowville wanna make a time to check it out?
https://www.sau.com.au/forums/topic/248527-r32-gtr-brakes/#findComment-4338377
No idea. sorry.
They are not Brembos and I can't comment if they are like them, but am not aware that they have any special offset requirements
I'm not sure what you're asking, but they say Nissan on them, and they are standard on the R32 GTR so yes, maybe?
I'm in Dandy South today, tomorrow, and Weds. I'll PM you my number, so call if you want to come see them.
https://www.sau.com.au/forums/topic/248527-r32-gtr-brakes/#findComment-4338379
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
