I've got a full set of brakes from my GTR as I've just done the big brake upgrade. For sale is the following:
Sumitomo calipers - std GTR spec
Braided lines from the group buy - all by brand new
RDA slotted rotors - all but brand new
QFM K750 pads with a set of DS2500 pads - both sets, front and rear at least 90%
All bolts, and associated bits 'n' pieces
I'll throw in the original rotors which are all serviceable too. They were machined 2,000kms ago.
All in PERFECT working order.
These come off my immaculate GTR and you can be assured they will bolt on and work how you want them to.
I will post at at your expense. Located in Dandenong Victoria if you want to pic up. Pics later......
$1,000 the lot.
https://www.sau.com.au/forums/topic/248527-r32-gtr-brakes/
Bump for those who want to buy this set up 'whole'. I'll be in touch with those that want parts shortly if not sold 'whole'. Slow down for the New Year with my brakes.
https://www.sau.com.au/forums/topic/248527-r32-gtr-brakes/#findComment-4338311
will these bold onto R34 GTT???
are these also like brembos where different offset wheels are needed???
also are these classified as standered nissan brakes that i would have on my GTT seeing as these arnt brembos??? also in rowville wanna make a time to check it out?
https://www.sau.com.au/forums/topic/248527-r32-gtr-brakes/#findComment-4338377
No idea. sorry.
They are not Brembos and I can't comment if they are like them, but am not aware that they have any special offset requirements
I'm not sure what you're asking, but they say Nissan on them, and they are standard on the R32 GTR so yes, maybe?
I'm in Dandy South today, tomorrow, and Weds. I'll PM you my number, so call if you want to come see them.
https://www.sau.com.au/forums/topic/248527-r32-gtr-brakes/#findComment-4338379
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
