any 1 go on it? saw the ceffy crash on way hm from work and heaps of cop bikes, undercovers and marked cars geting round... rumour has it they blocked off the exit of the meet point? :S
sum hero is also bagging the cops on there.... why do we bother!?
https://www.sau.com.au/forums/topic/248738-last-nights-ns-cruise/
I went past the meet spot after getting my Subway dinner :P
Lots of cars that the cops would have had fun with.
yeh my mate rammed the ceffy in his vs... everyone suddenly went on the brakes n he didnt have enough time to stop.. (his story anyways) my other mate almost went up his arse too in his s14.
Waaaaait. Oh I see but why did everyone suddenly go on the brakes?
Went to go get Macca's at Habour Town at about 12-1AM and was a few skylines there. Kahli, Brad, Luke, Tom (300ZX), then after I came out the drive through a heap of ceffy's and silvias showed up. Got out and started talkin to them till a cop showed up, they all took off pretty fast.
not sure, wasn't there.. was ripping my cars suspension out at home..
the ceffy also went up another cars arse from the vs too. that wasn't really damaged so he took off. Ceffy had to be towed home coz the radiator was pushed on to the fan i think.
I got there about 40min after it happened, the vs is a write off for sure, ceffy didn't look tooo bad but couldn't really tell till the bumper etc was off. The ceffy owner used to have an r32 so pretty sure hes around here somewhere...
the cops did nothing really, the mt barker cops were not alerted or didnt realise the cruise was on, so they just shuffled everyone along. only one guy got donw for running a red light and someone got a talking to regarding trade plate usage.
the cops where sweet, even at the meet spot one sapol car rocked up and did nothing as most cars slapped 2nd gear leaving.
great turn out, no real hassle, and some amazing cars
Looking at lastnights weather, kinda lucky there wasn't more accidents up the Freeway!
unless your being stupid, there shouldn't be any crashes even in those conditions.
that Sniper GTR was tailgating me for a bit, gassin it back n forth...my hero.
Edited by Ryanrb25
It was a NS.com cruise. Stupidity is after the 'N' in the URL.
It was not a bad night really, the highlight for me was the chick at Mt Barker running through the car park telling everyone that the cops where gonna block us all in, then watching people running for there cars so they could get away, it made me lol so hard. It was like a scene from a F&F movie :)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
