I recently returned from living in Japan and brought with me all the bits and pieces from the cars I drove over there. They are now taking up space here and I wanna be able to be able to park my car back in the shed so I'd like them gone ASAP. All prices are negotiable. Everything is in Mt Gambier, SA but can organise transport to Adelaide and I’ll be going to Melbourne with a truck mid January so if Melbourne buyers get in before then, transport can be arranged. Can arrange freight to other parts of Australia at buyers expense. My number is 0435 281 536.
Here we go;
SR20:
SR20 red top complete running engine (150,xxx km) with loom, Mines tuned ECU, aftermarket stainless steel exhaust manifold, alternator, starter motor, coilpacks, cas, A/C pump, water pump, oil pump, power steering pump, clutch, air flow meter, pod air filter, HKS blow off valve, engine mounts, manual gearbox and mount. $2,600
SR20 red top, suit rebuild. Loom included, water pump ok, one of the coilpacks is stuffed, cas is broken, oil pump is stuffed, sump is cracked (will supply brand new oil scavenger), turbo OK. $1,000
R32 rear stabiliser $20
Good, cheap upgrade for S13 Silvia/180SX
SR20 catalytic converter $20
S13 drive shafts L&R $30
SR20 intake manifold $20
S13 front brake/lower arm/tension rod/tie rod/hub assy L&R $100
S13 power steering reservoir $10
SR20 pot luck camshafts $100
Brand new, I’ve been told they are aftermarket but I have no idea of specs.
S13 oil pan guard $40
Aluminum bash plate for sic drifters
180SX rear member $400
With everything, diff, brakes, hubs, drive shafts, etc
180SX rear member $50
Just the bones, nothing attached
SR20 propeller shaft $50
BNR32:
I wrecked a GTR and have all the parts. The engine, loom, ECU, clutch, dashboard, bonnet, headlights, tail lights, indicators and front bumper lip have been spoken for, but everything else is available. Below is a bit of a list but if what you want isn’t there then just ask because I’ll probably have it, I just got sick of typing everything up!!
Seat belts $30
Hand brake, lever and lines $30
Front seats $300 each $500 for 2
Rear seat (2 piece) $200
Steering column $50
Side and Rear skirts $100
Boot lid + wing $150
Boot is in ok condition but the wing will need a respray. Sticker is free.
Rear bumper Reo $100
Rear bumper $200
No dents but plenty of scratches, need a respray.
Front bumper reo $100
Front bumper $50
Includes free crash damage……..
ABS unit $80
Radiator overflow bottle $20
Power steering reservoir $20
Fuel tank inc. pump $100
Rear sub frame member $1000
Includes everything (brakes, diff, drive shafts, hubs, etc.) except HICAS pump.
Clutch master $50
Brake master $50
RB25:
RB25DET engine with cut loom, ECU, clutch, possibly blown turbo, starter motor, manifolds. $1,600
ST185 Celica GT-4:
Apexi PowerFC + hand control unit for 3S-GT $900
Hand controller has some dead pixels, see photo
3S-GT ECU $200
Instrument cluster $100
Front fenders L&R $100
One small dent, surface rust on lip, plenty of scratches, need a respray. Stickers are free!!
Rear bumper $200
Bonnet $200
Rear hatch $200
Plastic rear quarter wing extension pieces are broken but are all there, should be repairable.
Doors $200
Front bumper and lip (big hole chopped out for FMIC) $100
Complete pop up headlight units $200
AE86:
Ducktail rear wing $120
Negative Camber RCA $40
Two sets of aluminum 30mm, one set of steel 22mm. None have bolts.
Toyota LSD 2-way centre to suit zenki shafts $400
JDM rear number plate housing $40
4AGZE (AE92 front wheel drive) complete running engine with loom, ECU, etc. Still on front member complete with struts, brakes, 5 speed manual gearbox. $2,200
4AGE (rear wheel drive (bigport)) complete running engine with loom, ECU, exhaust manifold. Also included is a complete engine overhaul kit (all new gaskets and rubbers), oil pump, water pump, timing belt and tensioner all new still in their boxes. $2,500
Various:
GReddy Rebic II $150
Auxiliary injector controller, complete unit, only missing injectors.
GReddy Rebic III $200
Toyota 90 series Mark II Vertex side and rear skirts $250
RB20 transmission $500
i'll take this pending pics
i'll also split posting to syd with anyone that is willing and wants stuff posted to syd
thanks!
Hey champ I will take the gtr side skirts and rear skirts.
I am in melbourne and can wait if you can drive them up mid january :(
cheers!
do you have a 32 gtr cooler?
Yep I do have it but unfortunately someone already has dibs on it. Sorry mate
Any chance you have the front passenger side half shaft off of the BNR32?
Yep, and I've sent you a PM.
Hey, I'm after the tie rod ends for front and the passangers side lower control arm (the part that bolts to the bottom of the suspension) for r32 GTR.
Also do you have the stone guards front and back?
PM back if you have :blink:
Edited by Helious
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
