any one experienced what im getting?
k now ive just recently wound my boost up to 11psi and when im pushing my car from down low, it hits 11psi
and if my rpm is below 4k its like it cuts out and comes back to life very quickly, almost like you're giving the
clutch a good ol poke, as soon as the rpm is above 4k it holds 11psi fine and doesnt miss a beat, now its already
got split fires, but im almost wondering if the fuel pump or injectors arent delivering enough fuel.
im still running factory injectors and sadly the ceffys na auto rb20e fuel pump, boss tells me fuel pump will still
deliver required fuel pressure so im unsure, im picking up an 040 soon so i guess ill find out.
the one thing that is making me reconsider that its a fuel prob is that my old factory rb20 skyline held 14psi no
probs and never let me down, i mean that felt like it had more poke than my 25
any one shed any light on my problem
cheers
nath
https://www.sau.com.au/forums/topic/248910-boost-surge-on-my-25/
yeah it is, i mean the car takes 9psi lovely, takes 10 even better but if i squeeze the throttle and make 11 too early, :D and the ghost has pushed my clutch pedal
theres no tune on the car, and my only mods are 3" tbe, front mount, manual boost cont, splitfires and a pod
mmmm indeed aye
mmmm ive heard that standard coil packs fail under higher than 10psi boost, now its not a constant prob, its only every 2-3secs under full load under 4k rpm
i forgot ive only got 5 splitfires and one standard coil
Hey man, i think im in the same boat or the one next to it. I think its my actuator. ill try changing it soon. its kinda like a mini surge aye, then hits you with full power again. I dont think itl be fuel related as it pulls hard to the redline, its just that tiny lil surge.
yeah im still runnin standard ecu but like i said, my 32 handled 14psi easy and that was all standard in terms of ecu, injectors etc, as for the surge itself, it feels like im stabbin the clutch every couple of secs till i hit anything over 4k, mysterys, gota love'm aye
^ +1 or get a PowerFC
You might have been running 14 psi in your R32, but 14 psi on an RB20 turbo is different than 14 psi on an RB25 turbo. (I realise that you are only putting it to 11psi and this is happening, just making the point that they are not equal volumes and therefore not comparable)
It has nothing to do with your injectors or any of the other stuff, its the standard ecu seeing too much air going into the engine, and retarding the timing (R&R= Rich and Retarded)
I've had this, its like it just drops into a lull, and then surges once you get over 4-4.5k.
haha ah i got ya now, yeah ill just drop it back to 10 for now, i got a gt35r going on later so ill need to upgrade comp and tune so ill wait till then to do that, cheers for the help fellas
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
