Anyone using one of these ?? Any experiences ?? Comments thoughts ?
Specs:
Garrett GT3040 Ball Bearing Turbo:-
Aftermarket Applications
Part Number #GSB8005A for 500hp
#GSB8006 for 600hp
Rated 500-600hp
Spec's:-
0.63 0r 0.82 /r Turbine Housing (4 bolt outlet)
0.70a/r Compressor Housing
Watercooler Centre
56 Trim Compressor Wheel (T04S)
55 lbs/min Comp Flow Max.
84 Trim Turbine Wheel
External Wastegate
$2500 new from GCG - Save $460 as it is on special now.
Seems like a good buy. But how good is the turbosharger ??
Considering the XTRGTST-STG2 500hp rated is $2450.00 - and that is on an exchange basis.
I understand that a bit of fabrication might be neccessary to fit the GT3040 to an R33 GTS-T ??
Thanks in advance.
https://www.sau.com.au/forums/topic/24896-gt3040/
Tony,
I think Andrew has the HKS 3040 - this one is a Garret GT3040 - buggered if I know what the difference is.
CGC say that these are either 500-600HP Turbo - but I think Merli's had more potential than that.
If they are similar, then I think may this one would be too laggy for an RB25 - But perfect for the RB30.
Needjapcar - looks sweet mate - yeah keep us informed !@
https://www.sau.com.au/forums/topic/24896-gt3040/#findComment-528984
Originally posted by T0nyGTSt
If you have the AR's you might be able to match it to the HKS 3040 AR's.
It'll give you an idea of spoolability.
T.
You cannot match the HSK ARs, as HKS has proprietry on them.
I am pretty sure Ben Ellis is using a Gt3040 on his GTT in HPI mag but with a 1.** turbine AR, also I think GTSt VSPEC just fitted one.
The hks 3040 uses 50 trim comp wheel, the 56 wheel is used on the 3037 by HKS? the turbine trim is the same.
HKS sell the 0.87 A/R turbine housing with the 3037 as a kit for the RB25, I currently have the 0.61 and although it makes good power at 1-1.2bar, I am sure it is going to choke the engine a bit up top once I start winding in boost, also it is only making 256 at 1bar, so probably a bit more with a larger AR on the turbine, which I intend doing soon:)
I think your choice boils down to where you want the boost and how much power you. The bigger the AR ratio the better the top end, more ign, more power for the same boost pressure - due to the reduced back pressure (the curse of turbo powered engine) but also more lag, although this can be offsett by the use of adj cam gears or cams.
Also if you intend doing cams you will get increased overlap, so a smaller AR could really cause troubles.
https://www.sau.com.au/forums/topic/24896-gt3040/#findComment-529052
Hi guys, that's the one, a Garrett based XTR GT3040, it's going on our RB31DET. If you are thinking of puting it on an RB25, you need to make sure you have the support systems to handle it. Camshafts (256's at least) are a prequisite, as are larger injectors, exhaust manifold, good wastegate, exhaust, intercooler etc etc. All that will make the cost of the turbo seem like a bargain.
PS; for the guys thinking about aftermarket plenums, Ben's car made the 290 rwkw and the 11.9 (I only saw the 12.4) with a standard RB25DET plenum.
https://www.sau.com.au/forums/topic/24896-gt3040/#findComment-529307
man i gotta subscribe to hpi, hate hearing about this in it i haven't seen!!!
anyway, i was thinking of this turbo too! didn't see the special on it though!!! this special takes almost $400 bucks off, should bring the turbo setup down to just over $4K!!
wish i had the money :D plus the $3K+ for support systems!!!
plus upgraded pistons for over 250 rwkw?????
expensive to be sure!!
any ideas on the power difference between using this turbo on RB25, and the RB30/25 setup? sydneykid?
https://www.sau.com.au/forums/topic/24896-gt3040/#findComment-530253
I'll have all the supports - including new (forged) internals, cams, etc - But still running the GCG Hi Flow turbo (500HP).
Thinking of upgrading to another turbo that flows better - But not sure if I can justify the cost right now - Maybe later.....
This GT3040 seems like good value.. I'll give GCG a call !
https://www.sau.com.au/forums/topic/24896-gt3040/#findComment-530454
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
