I have for sale my 1990 GTR. The car was recently up for sale. A potential buyer had the car checked and was found to be down on compression on 5th cylinder :( I was unaware of this before i advertised the car. For the last two weeks I have been deciding what to do...rebuild or sell. The reason i have chosen to sell is because i have just lost my licence and would like to free up some money.
All details on this car are on a previous topic of mine which im pretty sure you can find by looking in my profile?
Any queries or probs gis a text or call Carl on 0420783616
The car is in VIC and has 10 months reg, 122000ks a few extras/mods etc call for more details
This car has not been used since this was discovered.The car is still very drivable and fast but obviously will need something done about the loss of compression.
Best offer over $10,000
https://www.sau.com.au/forums/topic/249071-r32-gtr/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
