Be careful on repaired vehicles offered for sale out of Japan.
Be carefull as some people are offering repaired modern cars for sale out of Japan as they are cheap but may end up costing you your car.
The rule is below so read into it dont take somebodys word for it.
A RAW would take all reasonable steps to avoid importing a crash damaged or corroded vehicle.
A RAW wont put up his bussiness to save you money.
In a nut shell they are saying dont bring in a damaged or repaired vehicle. I know of one complyier who knocked back a car as they were told by the importer it is a repaired vehicle but only minor damage. They knocked back the work and said unless you are 100% sure it is minor it will be at your cost. So the buyier went back to the broker who wouldnt sign a document that the car will pass the RAWS inspection then the importer went a bougt a straight as car to save the trouble.
Damaged Vehicles
Crash damage or corrosion may affect continued compliance with the ADRs. This is especially so in the case of the occupant protection ADRs 69, 72 and 73. It is not possible for a RAW to provide a reasonable level of assurance that a crash damaged or corroded vehicle, where the structural integrity of the vehicle has been affected, complies with all of the applicable ADRs. Therefore, it is not permissible for a RAW to fit a used import plate to such a vehicle.
Before commencing compliance work each vehicle must be inspected by the RAW to check for crash damage, damage repair or corrosion that may affect the structural integrity of the vehicle. Records of this inspection are to be retained by the RAW and be made available to VSS inspectors upon request. (Regulation 57)
Crash damaged or corroded vehicles where the structural integrity may be affected must be re-exported or destroyed. It is expected that a RAW would take all reasonable steps to avoid importing a crash damaged or corroded vehicle.
The criteria below must be used as a minimum when deciding if crash damage or corrosion is likely to affect the structural integrity of the vehicle.
q Underbody damage which results in the:
Ø crushing of floorpan stiffening members,
Ø splitting of seam welds or
Ø tearing of the metal
q Damage to rocker panels (or outer sill) which result in:
Ø Dents to a depth of more than 25 mm
Ø Creasing, distortion of the sill weld
q Distortion to longitudinal rails affecting the front and rear crush zones.
q Collision damage to steering or suspension components.
q Damage to the vehicle’s outer body panels, which affect the integrity of any of the seams or joints installed by the vehicle manufacturer.
q Corrosion (rust) which has resulted in perforation or flaking of the metal.
When checking the condition of the vehicle the following items need to be inspected but not necessarily in this order:
q Engine compartment
q Right side
q Luggage cargo compartment
q Left side
q Underbody or chassis frame
q Passenger compartment
I reckon this is bogus...given the bombs floating around on the roads......and the fact that people can fix cars with $25,000 worth of damage once they're here...go figure.
I suspect that the viability of buying a vehicle through a broker will be seriously rooted by the time RAWS is in full swing...
Predicated by my previous "Broker" experiences, I don't think I'd be willing to take the risk of them giving me poor advice/support.
Which I suppose is a good thing. If people are willing to pay car yards like C-red to perform that service for them, it will only help to ensure that the value of imports already in Australia remains high.
but you can say goodbye to almost all S13s....are there actually any non-accident repair silvias?
The cars are out their, it is all about who do you trust.
A person with a lot to lose.
Or somebody with nothing to lose that says it is all at your risk.
I drive a 1980 Datsun 720 that came here with 4000 klm it just clocked up 7000 klm and two RX7's with under 60,000.
It is all about your buyier and workshop just be carefull and ask a lot of questions.
This,
Minor front accident repaired vehicle but the repair is excellent.
Radiator support and LHF inner repaired.
Dosent equal this,
As per DOTRS requirements.
So guy's be carefull as it is your money that is lost.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
