Hey guys i am new on here as i jsut sold my MKIV Supra and bought my self a immac R32 GT-R
Currently it is gunmetal grey
veilside exhaust
Veilside dumps
Boost controller
controller to swap from awd to rwd
unkown intercooler
Bosch fuel pump
Unkown clutch feels likes a twin plate button
Coilovers
Nismo lip wing
Future(very near future):
parts on order:
PFC
272 degree cams (HKS)
adj cam gears (HKS)
HKS timing beltVolk GT-C's 19x10.5 86mm dish gold face.
Parts to buy still:
twin t2860-5's
ARC radiator
Injectors
Forged pistons
Nismo gauges
H-Beam rods
titanium valve springs oversized valves
CRD sump and oil pump
Hopefully all to be done by May 09'
My name is Mitch and i live in Cheltenham,Vic work in Knoxfield.
Hey man welcome to SAU!
Nice list of mods on the car already sounds sweet, and god damn.. nice shopping list there haha!
Have fun!
MRXTCZ
thanks mate and yes i cant wait should be fun and a learning experience i have gone from a VLT to a tt 6spd supra to a r32 gtr now so three totally different cars.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
