Hey guys,
There are 2 rubber fuel lines going to and from the tank on my gtst. they are very old and brittle and need replacing NOW.
(one started leaking - thats how i noticed)
getting to the front of the pipes (where they go from rubber to matal) is easy as this is infront of the tank.
hard part is the back as the pipes dissapear in above the tank.
so.. has anyone ever dropped a tank down? it is just a matter of removing the filler pipe
and then lowering the tank down onto stands by undoing the 'straps' that hold it?
any advice appreciated
*sigh wish i posted this earlier*
Kind regards,
Zennon
https://www.sau.com.au/forums/topic/249619-how-to-removelower-r32-fuel-tank/
ok so here is how the events transpired yesterday.
step one - reverse sexy skyline onto car ramps
then thought i would have to remove the filler pipe from the tank here
then realised thats crazy talk - all id have to do is remove this bolt where the filler pipe bolts to the car
like so
and rubber around filler hole just pushes out like so
then undid the two straps holding tank like so
then noticed wire going into boot pulling tight so thought i better open boot
so yeah opened boot - plug is under that silver cover
(also note here the little panel i could probably have done this job through if only i opened the boot BEFORE dropping the tank!)
here we can see the wire going into the boot (vertical wire) and then the two pipes im replacing
one fuel line going to engine and the other the return i assume
(or maybe that third pipe i didn't touch is the return - ah who cares anyway)
this is one of the old pipes
and here it is with my fancy new ones
old ones were 8mm but replaced it with 7.5mm since thats the closest thing superfags had
  • 2 years later...
hey mate im reading your tutorial (which is great btw) but i cant workout how you can get to fuel lines without lowering the tank coz as far as i can see the lines run along the top of the tank, between the tank and the car(underside of the boot floor). i may be wrong about this as i haven't has TOO good a look yet. My 32 gtst was leaking fuel the other day after running for awhile. It leaked overnight and has now stopped. So I'm not sure if it's a busted seal or busted hoses (the car hadn't been started in 2 years due to defect) the car is actually running pretty good right now but im worried about this leak. The thing is- I ran the car for 15 mins today and it didn't leak a drop so I can't even see where it's leaking from and am confused. Sorry for the gigantic post. Hopefully anyone else reading this can offer some helpful insight.
Cheers in advance!
  • 1 year later...
I strongly recommend not removing filler necks at all unless 100 percent nessesary, the o rings expand with fuel fumes hitting them if your lucky you can reuse them but the best thing to do is keep neck on and remove the pump than the line next to pump, I just lowered with jack, when raising have someone to make sure filler neck is in right position or It can get messy lol trust me from experience. Of you do remove filler mark location cause there is 6 different areas it can go back into :)
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
