I thought I’d show you guys the new compressor covers.
The NEW race cover is standard fitment on all the 70mm to 76mm Billet turbos and all the 66mm to 75mm (ETT) S Series Billet Turbos
The Big cover in the pic is the Pro DRAG cover. It suits all the Pro DARG turbos from 88mm to 106mm
Sorry for the picture quality. They were taken on my phone.
Inside Billet GTSR compressor cover. Note the extended defuser area.
Here is some pic's of other compressor covers to compare.
Garrett TA cover. (Cover used on Garrett T51R)
Garrett GT42 cover.
https://www.sau.com.au/forums/topic/249683-new-compressor-covers/
Hi Ricky , yep definitely a step in the right direction .
I don't know if people remember but HKSs TO4Z comp covers are a bit like that diffuser diameter wise as are many of the truck ones on Holsets and possibly Borg Warners .
I'm not sure if the cross section of that housings diffuser is like OEM ones are , would need to cut them open to find out .
Diagrams I have of housing cross sections show the diffuser to be reasonably thin walled and I suppose thats to take up minimum area of the housings volute passage .
The diffuser section of any radial compressor housing is critical because its where velocity energy is converted to pressure energy .
Often when a turbocharger is "high flowed" with a larger diameter compressor wheel in the same cover this area suffers because the wheels diameter is larger but the diffusers diameter stays the same .
Cheers A .
Hey Disco, Thanks for the comments mate.
Not all the HKS T04Z have the extended defuser area. I have seen both some with and some without.
You will find the newer HKS T51R KAI and SPL have a similar defuser area.
Another cool update is the Billet 76-GTS is available with a T7 billet compressor wheel. The model is called B76-GTS
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
