Marcus.... dunno about Mobil R but many friends use Mobil 1.... Motul is used by many places including UAS.... oh and I forgot.. NISMO use it as well...
those are both fine. For more exp stuff you can try Royal Purple which is sold at C&V. I have Hytech (or however you spell it) which is the standard oil used by Hill Motorsports (where i got my car serviced) and also C&V use this.
I think any of the above will be fine for your car... you jsut need to find out what grade... maybe 10W40? not sure.
But definitely run a search man...
If you are gonna get a service go to Hills motorsports... or gie me a call I can talk to you about it
Cheers
https://www.sau.com.au/forums/topic/2497--/#findComment-45876
Hey 400, yeah i jsut went to powerplay imports to get motul 4100
its semi synthetic rated at 10W 40.
I cant report any noticeable differences yet.. but we'll see when i make the next oil change in 5000K's...ill let ya know how burnt it is...
hey yang if u get this msg..call me thurs or fri nite just to confirm it all..thankx
oh yeah forgot..i am m'sian chinese...are you?
oh and i agree...C&V are on the steep end of the market..but i spose they know what they are up to..
mc
:shake:
https://www.sau.com.au/forums/topic/2497--/#findComment-46506
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
