Hi ppl,
I am having some problems with my car right now... The boost is not holding and its misfiring aswell. its been in and out of the workshop a couple of times (mostly a week at least).
Trying to diagnose the problem but still having the same problem every single time.
Just had my car tuned, unopened engine, gt30 internal gate and all supporting mods. Service was done and sparkplugs changed, coilpack changed(splitfire), using AVCR(all lines checked, solenoid working), Power FC tuned to 350hp 1.1 bar.
When i give the car a rev, hits full boost it either misfires or doesnt hold the boost. (Check AVCR- it goes to 1.3bar!!!!!)
Goes to low setting 0.8 goes up to 0.95bar. Feels like lack of power even when it hits full boost(without misfire).
mechanics done has checked everything but it still does the same thing everytime.
Any ideas??
Thanks inadvance!
https://www.sau.com.au/forums/topic/249770-boost-creep-and-misfire/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
