hi guys selling up all the goodies was gonna make a drift car but over buying parts lol here is a big long list with pics
rb25 block rings gone $100
rb30det fresh bottom new belt and head gasket, rb25 head with 25 bolts also rb25 oil pump and sump ready in 3 weeks$1200
high mount stain less mani brand new $150
46 mm gate in blue colour $150
big garret spec ball bearing turbo .70 front and 1.16 rear good for 25 or 3.0 ltr. $550
r31 series 1 shell that can be regoed $300 old drift car
r31 mini spool diff centre $80
rear twin r31 sway bars $100
surgetank polished with bosch pump $200
s13 lower control arms in r31 for $100
manual conversions for r31 everything but box $$200
r31 coilovers with s13 brakes at front complete package still in car $500
r31 panel headlights tail lights dash everything in stock just ask and offer cash
drift teks 17x8 and 17x9.5 muti stud will have painted white before sale, $1250
r31 skyline auto and in stock form for $1800 will be in cars trader and thats off the top of my head,
pm all parts are located in ADELAIDE
sell sell sell cheers
https://www.sau.com.au/forums/topic/250237-fs-r31-goodies-all-drift-spec-gear/
I can give you a $1000 cash for the rb30det asap. Or just the bottom end for a cheaper price, or all the bits in pieces whateva is easier for you.
Can you please call me on 0433333647 as I don't often get internet access.
Thanks, Jack
  • 4 weeks later...
hey mate
manual conversions for r31 everything but box $$200.
Does that include flywheel, clutch?
r31 coilovers with s13 brakes at front complete package still in car $500.
any pics very keen
  • 1 month later...
  • 10 months later...
  • 7 months later...
  • 3 weeks later...
manual conversions for r31 everything but box $200
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
