150rwkw/200rwhp out of an RB25DE is going to cost you.
Machine work (porting will have to be done and getting the compression up, 10.5:1 probably won't cut it, you should be trying for 11:1 - 11.5:1 for 2.5lt and costs for big cams also)
About - $4000
Aftermarket ECU - Min $1000 then to wire in and tune another $1000
Decent Extractors - $1000
Labour - min $1000
Cams and springs - $1500
Oil an water pumps - $500
Exhaust piping - $750
Lightened Flywheel and new clutch - $1000
So about 11G should net a figure around 150rwkw probably 160 - 170rwkw, but in saying that people would say you spent all that money and get such a tiny power figure, but really that setup would be good for a mid - high 12 to low 13 sec quarter pass which isn't slow for an N/a
umm..id like to do the same to my 34 is he said that hes got an auto soo wat would be the kw without the clutch
https://www.sau.com.au/forums/topic/250316-na-tune/page/2/#findComment-4379988
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
